3rd Gen Durango 2011+ models
Clicking Noise
Old Aug 2, 2012 | 09:36 PM
12HemiR/T's Avatar
12HemiR/T
I hear the clicking noise in my D (manufactured 04/12). Almost sounds similar to the A/C compressor engaging/disengaging, but it is not. I will add this to my running list of issues for dealer to fix on the next visit (pending A/C remote fix announcement):
  1. Clunk from left rear (visit #2)
  2. A/C does not work using remote start
  3. Solenoid clicking noise
But still love the truck!!
Old Aug 3, 2012 | 07:19 PM
hwy101's Avatar
hwy101
same click noise here thought it was one of the calipers
Old Aug 4, 2012 | 08:33 AM
gabarit's Avatar
gabarit
Hey 12HemiR/T
Please keep us posted if you go to the dealer soon and find out what the click is.
G.
Old Aug 5, 2012 | 01:01 PM
12HemiR/T's Avatar
12HemiR/T
Originally Posted by gabarit
Hey 12HemiR/T
G.
Will do. Hoping for next week.
Old Aug 7, 2012 | 07:21 AM
gabarit's Avatar
gabarit
Hi,
I visited the dealership today for the 1st service and had them listen to the clicking noise.
The mechanic said it's normal and it's coming from the gearbox. He checked and there is a bulletin issued on Aug 2nd, 2012 which describes a fix for " harsh shift from Drive to Neutral". He thinks it might be related also to this noise.
The reason it's not in all cars: it all depends which factory the gearbox came from!
Hope this helps, if you guys find more info, please let us know...
G.
Old Aug 7, 2012 | 09:24 AM
DodgeCares's Avatar
DodgeCares
Hi,
G.
G,
Here is the bulletin the dealer was talking about. Does not mention anything about a clicking noise though.
NUMBER: 21-010-12
GROUP: Transmission and
Transfer Case
DATE: August 02, 2012
SUBJECT:
Noise Heard When Shifting the Transmission From Drive to Neutral
OVERVIEW:
This bulletin involves installing a revised separator plate into the transmission valve body.
MODELS:
2011 - 2012 DD Ram 3500 Cab Chassis
2011 - 2012 DJ Ram 2500 Pickup
2011 - 2012 DS Ram 1500 Pickup
2011 - 2012 WD Durango
2011 - 2012 WK Grand Cherokee
2011 - 2012 W2 Grand Cherokee (International)
NOTE: This bulletin applies to vehicles equipped with RFE transmissions only
(Sales Codes DFP, DG7, DGQ, or DG1).
SYMPTOM/CONDITION:
Harsh/audible shift from Drive to Neutral predominately with elevated ambient and
transmission and driveline temperatures.
Old Aug 7, 2012 | 03:35 PM
dwolson2's Avatar
dwolson2
I also have the "clicking noise", but sounds like a bushing issue. I don't have adaptive cruise, I know its not AC. And I don't have 4wd(not CV shafts). It doesn't appear break related since it doesn't change with or without the breaks applied(most break related noises change when you apply or don't apply the breaks)
What solenoid would be clicking?
Its really annoying. I can reproduce it, over and over again. Its at speeds lees than 10 MPH with the radio really quiet(lol)
FWIW I have a 2012 Crew Lux w/20" wheels
Old Aug 8, 2012 | 11:38 AM
gabarit's Avatar
gabarit
Hey Chris,
Yes this is the one the dealer told me about. I did a test yesterday: while the D. is at stand still, shift from D to N and you'll hear the same clicking noise at the beginning of the shift. I am hoping that changing that plate will get rid of the noise.
G.
Old Aug 8, 2012 | 11:41 AM
gabarit's Avatar
gabarit
Hey dwolson2,
It "appears" it it something inside the gear that makes this noise and requires changing a plate. I have the same D. you have : crew lux with 20 inch wheels. Your symptoms are exactly like mine.
I'll let you know guys once the dealer applies the change to my D. It'll be probably a while as I'll be away travelling. If you guys get it done 1st, let us know.
G.
Old Aug 8, 2012 | 11:52 AM
DodgeCares's Avatar
DodgeCares
Hey Chris,
G.
G,
If you or anyone else on here has this TSB performed and it corrects the issue, post it up on here so others will be aware of the possible fix for a similar condition. Thanks...
