Last edit by: IB Advertising
Browse all: Lighting
- Dodge Ram 2nd Gen How to Install HID Headlights
Step by step instructions for the do-it-yourself repairs.
DIY: Head Light Bulb / HID Install
If anyone could list the steps needed to take the bumper off I would greatly appreciate it! I hate trying to guess at it when it come to the bumper because there are some things that snap and push and I usually end up breaking off a few tabs when I try to figure it out
@darkmanrob did you have any fitment issues when you installed the bulbs? Im guessing its much easier to kinda force the bulb into the housing when everything it out but man does this suck just to replace a bulb
Naw I haven't tried. Do you think the ECEs are interfering with the power flow from the factory wire harness to the ballast? I'll remove the ECE from the driver side hid light and see what happens this weekend.
I'm not for certain with the headlights and ECEs....but for my fog lights, taking the ECEs off made the fog lights come on consistently and works flawlessly. I did, however had the same problem with my fogs as you did with your headlights when I installed the ECEs. That's why I took them off. Just them off and see if it works out for ya.....
That access panel in the tire weld sure does make things A LOT easier. I took some pics but the ebay kit came with its own frustration so i am just going to go with silverstar's and stop messing around with the HID kits. I should have known better, if you want HID's get them OEM and dont try messing around with el cheapo aftermarket ones. Pictures to follow soon
