Does my Heat have a sub or not?
I have the alpine system, some websights say its a ten speaker system, some say its a 9 and the dealer has to mail me my manuel so im confused. the system sounds great but im not gettin subwoofer base out of it. i found in the back where its got the alpine stamped in the plastic but i assumed thats where the amp is? someone please help with this probably dumb question. thanx
dont have one, it was a test vehicle, it was new but had about 500 miles on it.. so no window sticker and no manual as of now, its in the mail
The manual isn't going to tell you anything, its the same manual thats in all the D's.
You going to need to go to the dealer and have them look up your vin number because the only way to tell is it you find the sub or have the window sticker....
im pretty sure its the regular system and the alpine system, same thats in the R/T so i figured someone would be able to answer the question just out of owning one, but ill go to the dealer if not
under the cargo cover in the rear if you have that plastic box that is stampped with the alpine logo that is the factory sub. the part you can see is actually just a cover the actual box is a seperate item mounted below it.
The factory amp is located next to the pocket on the drivers side in the rear under the flash light.
Trending Topics
