3rd Gen Durango 2011+ models
Simple question about BT Catch can install
Old Apr 18, 2012 | 07:10 PM
jdloyd01's Avatar
jdloyd01
Default Simple question about BT Catch can install
Just got my BT catch can and I have a simple question. Where is the PCV line on a 5.7? I pulled the top cover and found a tube on the passengers side of the engine running from the rear to the front. It had some sort of twist of looking thing at the back. That seemed to be the PCV. Just wanted to make sure I had the right connection before I plan out hose routing and such.
Thanks
Old Apr 19, 2012 | 06:35 AM
coldsteel's Avatar
coldsteel
Yes, that is the PCV and has a single hose. You take that off and use the 2 new lengths of hose to connect with the catch can in the middle.
Old Apr 19, 2012 | 05:51 PM
CMil527's Avatar
CMil527
Pics? whats cost on the BT Catch Can?
Old Apr 19, 2012 | 09:50 PM
SINISTERRT's Avatar
SINISTERRT
I have a BT can too and yes you are right.
Old Apr 20, 2012 | 06:35 PM
jdloyd01's Avatar
jdloyd01
I haven't put my on just yet. I still deciding on a location for the can. Here is a post that has a pic: http://www.durangoforumz.com/showthread.php?t=765
I'll either copy that or mount it off the front of the fuse box. I like that location a bit better, but I will have to fabricate a mounting bracket for that location.
I got the same setup as the post $137.50 shipped. Its basically the no frills version on the BT site.
Thanks for the help guys
Old Apr 20, 2012 | 09:16 PM
CMil527's Avatar
CMil527
Thanks for the link and price, might be worth getting. I had one on my bmw 335i and it did its job fairly well.
Old Apr 24, 2012 | 11:15 AM
GoldRangoTX's Avatar
GoldRangoTX
Default BT Catch Can
I purchased the BT catch can and installed with an aluminum bracket. Nick at BT said they don't currently support the Durangos yet. I made a 7" bracket from 1" aluminum, attaches to the bolt holding the belt guard right below the TB. Can is in place right behind the coolant tank.
Old Apr 24, 2012 | 11:26 AM
GoldRangoTX
Photobucket link:
http://i1054.photobucket.com/albums/...angoTX/055.jpg
Old Apr 24, 2012 | 11:30 AM
CMil527's Avatar
CMil527
Nice job!
Old Apr 24, 2012 | 11:58 AM
GoldRangoTX
Thanks man. After about 500 miles, it had about 2 ounces of oil/gas gunk in it.
