3rd Gen Durango 2011+ models
push button start and proximity
Old Apr 25, 2012 | 07:13 PM
Scottina11heat's Avatar
Scottina11heat
Default push button start and proximity
So I was checking out my build sheet last night and according to the Jeep guys I should have push button start. I have code XBNP Tip start listed on my build sheet....which is the code for the push button/proximity. Is this standard on the Durango Heat? Its standard on all Jeeps from Laredo E package and up. I bought the push button, installed it and it doesnt work! Just says damaged key on the evic! Any insight?
Old Apr 25, 2012 | 07:20 PM
coldsteel's Avatar
coldsteel
Tip start IS NOT pushbutton ignition. Tip start means that all you have to do to start the car is turn the key to start for an instant ('tip') and the starter will engage as long as necessary to start the vehicle and stop when the engine starts. With the computer controlled ignitions on these vehicles, you CANNOT engage the starter (the computer will not engage the starter) with the vehicle already running.
Old Apr 25, 2012 | 07:50 PM
Scottina11heat
ok...what is the code for the push button/proximity on the durango? Cause the xbnp tip start is what is on grand cherokee build sheets
Old Apr 26, 2012 | 01:11 AM
IndyDurango's Avatar
IndyDurango
There is a D Push Button Start for sale here in another thread. Really cheap IIRC.
IndyD
Old Apr 26, 2012 | 04:33 AM
coldsteel's Avatar
coldsteel
Okay the Dodge Owners' site lists Keyless Entry, Remote Proximity Keyless Entry and Keyless Go separately and my window sticker says 'Keyless Enter-N-Go'
I cannot locate the XXXX code for it however. Have you tried the Owners' site?
Beyond that, my 2008 Charger is listed as having 'Tip Start' and Pushbutton wasn't even available then. Sorry.
Old Apr 26, 2012 | 11:16 AM
Scottina11heat
ok...thanks for info
Old Apr 29, 2012 | 10:16 AM
5.7HemiSport's Avatar
5.7HemiSport
Off My 2012 RT Build Sheet with Keyless Touch N Go / Push Start.
GXDS Remote Proximity Keyless Entry
GX4S Keyless Go
GXMS Remote Keyless Entry
GXXS Sentry Key Theft Deterrent System
XBMS Remote Start System
XBNP Tip Start
All are listed under the Standard Equipment except the tip start, listed as optional equipment (fwiw).
Old Apr 29, 2012 | 02:07 PM
Scottina11heat
cool...mine doesnt list any of that except the XBNP
Old Apr 29, 2012 | 03:14 PM
5.7HemiSport
I added the MOPAR remote start to my RAM. When they got done programming, the Info center had new options. Sure its the same if you want to retrofit a kit on your D.
