3rd Gen Durango 2011+ models
OK Guys just need a little info !
Old May 8, 2012 | 10:57 AM
  #21
Mike D.'s Avatar
Mike D.
Did you take that piece out of the air box to put on the filter. I am trying to get it in the box with no luck ??
Old May 8, 2012 | 06:44 PM
  #22
MrSnowflake's Avatar
MrSnowflake
Which piece are you referring to? The air box itself should be wide open with a lip the same size as the opening on the filter. It's a bit of a squeeze but certainly not a challenge to get the filter pressed onto that lip. I also recommend putting the filter on and tightening down the ring while it is separated from the vehicle...too much hassle with the air box in place, if not impossible.
Shoot some pics to let me know where your troubles are and I might be able to help.
Old May 11, 2012 | 06:01 AM
  #23
wildspeed's Avatar
wildspeed
D ran flawless all week after the pcm flash (18.035.11) and stock air box.
Also the D was much nicer & smoother to drive after this flash.
Put back the Volant last night and let's hope the problem doesn't reoccur.
Old May 30, 2012 | 09:49 PM
  #24
wildspeed's Avatar
wildspeed
Durango started to act again all weekend....
Took it to the dealer Tuesday morning.
Verdict : PCM shot , new one installed...hopefully this time it's fix...
Old May 31, 2012 | 10:09 AM
  #25
Rufio123's Avatar
Rufio123
Just curious if you've been bringing it to the dealer with the aftermarket intake still installed. And if so, what has been their reaction when diagnosing issues with a non-OEM part installed in the engine. Are they quick to point blame and warranty issues with the intake?
By the way I've had my Volant installed for two weeks with no issue. Even took the Durango long driving on a weekend trip.
Old May 31, 2012 | 11:08 AM
  #26
wildspeed's Avatar
wildspeed
Yes I did leave the volant installed, was not even mentionned at any time.
Was just a coincidence that the problem happenned at the same time that I installed the CAI.
Had to hit the PCM for the car to start.....
Old Jun 5, 2012 | 04:28 PM
  #27
wildspeed's Avatar
wildspeed
So far, so good... D is starting everytime and run smooth...
Old Jun 5, 2012 | 05:32 PM
  #28
CMil527's Avatar
CMil527
Good news, hopefully you won't have anymore issues!
Old Jun 6, 2012 | 04:22 PM
  #29
wildspeed's Avatar
wildspeed
Guess I spoke to fast again..
D back to the dealer, starting problem again and sputtering...
At least now I know how to start it without calling the tow truck...
