3rd Gen Durango 2011+ models
Water leak... Beware
Old Jun 25, 2012 | 02:33 AM
PortAuthorityCop's Avatar
PortAuthorityCop
Thats a tough one..had that happen in one of my other vehicles.. Get some Blue Magic or Blue Coral..forgot name and its downstairs in the garage. silver can with blue label and its upholstery cleaner sold at autozone walmart..should take those fingerprints right off..just remember to dab it not rub..
Old Jun 25, 2012 | 03:37 PM
JRRF's Avatar
JRRF
In days of old, if the sunroof leaked you got water in your car. This was an all too familiar problem for all makes and models. They then finally had the realization that you can't keep water from getting into a hole in the roof. Then the bright idea of a drainage system was introduced, and now all sunroofs have it. Your sunroof is actually designed to leak (or not designed to prevent leaks), and the drainage system is designed to channel that water away. The only significant problems now are when the drains get clogged. If you use your sunroof a lot and get any debris in there, you may experience this. It's unfortunate that they messed with your headliner, because usually the drain is easily accessible from the sunroof opening.
Old Jun 25, 2012 | 08:00 PM
2012sxt's Avatar
2012sxt
the sxt i bought did not come with the sunglass washer option my sunglasses are always dirty and smudged, i really could have used this, i should have bought a citadel
in all seriousness though I hope they get it fixed and fixed right the first time!
Old Dec 28, 2012 | 08:56 AM
981cedarmtn's Avatar
981cedarmtn
Default 2012 r/t
I have a 2012 R/T with no sun roof and it is leaking in the same area. Does not leak always, a few drips from the sun glass holder. Any thoughts?
Old Dec 29, 2012 | 12:00 PM
440sixpack's Avatar
440sixpack
I thought my issue had been resolved, but after some heavy rains last week it happened again. I'm going to give the dealer and earful next week.
Old Jan 2, 2013 | 04:23 PM
DodgeCACares's Avatar
DodgeCACares
cedarmtn,
Have you had the vehicle looked at by a Dodge dealer? If you are unable to find where the problem is coming from I would recommend having the vehicle diagnosed by a Dodge dealer. If you need additional assistance feel free to contact myself or my US counterpart Chris, DodgeCares. You can also contact the Customer Care Department, numbers below.
Canada: 1-800-465-2001
U.S.: 1-800-992-1997
Old Jan 2, 2013 | 05:07 PM
mmillerao's Avatar
mmillerao
Had the same issue when the truck was brand new, probably less than 1,000 miles. The dealer reproduced it with a hose and said it was the sunroof out adjustment. Whatever they did, it fixed it. At 12,000 miles now, no further issues.
Old Jan 15, 2013 | 09:22 PM
440sixpack's Avatar
440sixpack
Got the Durango back today from the dealership. Turns out it wasn't because of the sunroof. Apparently from the factory they did a crappy job, and the tech found a 'lack of silicone present' at the top-middle of the windshield seal. They re-installed it and found no further leaks.
We'll see, hope that was it...
Old Jul 7, 2014 | 10:58 PM
981cedarmtn
Default Water Leak
I'm still dealing with this water leak, The 2012 Durango has NO sun roof and NO roof racks. I've went to three different dealers neither could reproduce the leak. I have pictures and video of the leak. I've opened two complaints with Dodgecares but have had no luck having the leak fixed. I can't count how many days I've been without the durango. The last dealer finally did something by replacing the windshield but the leak is still there. I'm on the brink of calling the lemon law attornies. Dodge says they carebut my car still sits at the dealer for another week again. Any thoughts dodgecares.
Originally Posted by DodgeCACares
cedarmtn,
Old Jul 7, 2014 | 11:59 PM
440sixpack's Avatar
440sixpack
Suggest they look at the area I mentioned in the post above your comment, that fixed my issue which sounds similar. I've had no more leaks since then.
