3rd Gen Durango 2011+ models
New member w/ rear suspension issue
Old Jul 29, 2012 | 05:54 PM
  #31
12HemiR/T's Avatar
12HemiR/T
The thing that drives me crazy is that the noise only comes from the left side, so there has to be something else wrong.
Old Jul 29, 2012 | 06:39 PM
  #32
DJ Hellfire's Avatar
DJ Hellfire
Yeah, it's weird!
Old Jul 30, 2012 | 08:14 PM
  #33
hwy101's Avatar
hwy101
check the jack under the 3rd row drivers side might be loose
Old Jul 30, 2012 | 09:17 PM
  #34
12HemiR/T's Avatar
12HemiR/T
Nope. Already ruled that out with a road test sans jack assembly.
Old Aug 12, 2012 | 12:32 PM
  #35
jwr9152's Avatar
jwr9152
I mentioned in another thread that I changed my endlinks to Bwoody. After changing the back, I took the car for a test drive, and got the rattle in the back left. The endlinks were tight, but I tightened them some more and it fixed the problem. Similiary on the front I was about to start changing the front and put a wrench on the nut that holds the endlink on and the bolt and nut turned together less then a quarter of a turn. Had to stop and run to the store, and that little bit made the front start to rattle, so when I got home I tightened it as much as I could and that seemed to fix it. Just thought it might be worth looking at. They seem to have to be incredibly tight not to rattle.
Old Aug 20, 2012 | 12:03 AM
  #36
adbutz's Avatar
adbutz
Hey hwy101. When you changed your rear shocks did you have to change the springs. I have a similar issue with my rt. I've tried to let it go but I just can't. I've let air out of the tires in hope it would help and it has, but not enough. I see the part numbers you have added....are they the shocks for the citadel or crew. Will it change the ride height and do you know what it will do to our towing capacity.
Old Aug 20, 2012 | 10:09 PM
  #37
hwy101's Avatar
hwy101
no just the shocks i have the part numbers in an earlier post
Old Aug 20, 2012 | 10:11 PM
  #38
hwy101's Avatar
hwy101
Default rear shock part numbers
here are the part numbers for normal duty shocks YOU CAN NOT TAKE APART UR SELF LEVELING SHOCKS, ONE COMPLETE UNIT CANNOT USE PARTS SO U HAVE TO ORDER NEW SET UPS NORMAL DUTY HERE ARE THE PART NUMBERS THAT ARE NEEDED COST 177.00 COMPLETE. 68069846AF SHOCK ,68029522AA DUST BOOT,68029590AD SHOCK MOUNT, 68060590AB SHOCK MOUNT PLATE, 68063781AC SHOCK BUMPER ,ALL THESE COMPONENTS ARE NEEDED
here u go
Old Aug 20, 2012 | 10:14 PM
  #39
hwy101's Avatar
hwy101
these shocks will fit all the durangos i am personally not going to tow 7400 lbs it all varies u should be fine i couldnt live with that constant clunk eventually i will get the bilsteins when they come out
Old Aug 20, 2012 | 10:16 PM
  #40
hwy101's Avatar
hwy101
it will level out the front and rear will be the same height
