3rd Gen Durango 2011+ models
Will 285/45/22 Fit under the Rango
Old Mar 3, 2013 | 09:27 AM
Clifford R/T's Avatar
Clifford R/T
Default Will 285/45/22 Fit under the Rango
I am trying to work out the Viper reps and the tires I want are 285/45/22. I know the standard 22" tire is 285/40/22. Any of you guys that have bought them know there is not many options. I looked in the search bar and so far have not found anything. Thanks in advance.
Old Mar 3, 2013 | 10:09 AM
MJNewman's Avatar
MJNewman
The big advantage of the 40 series is the speedo will not be off. At 70 mph your speedo is only 1 mph off. Plus I can turn full lock both ways with no issues.
Old Mar 3, 2013 | 10:40 AM
CMil527's Avatar
CMil527
+1 to mj's comment and the 40 series offers a decent sized sidewall so you shouldn't have an issue.
Old Mar 3, 2013 | 11:00 AM
boosted20v's Avatar
boosted20v
I went 265/40 and it's perfect!
Old Mar 3, 2013 | 01:50 PM
Clifford R/T
Thank you guys, I am not good with tire sizes but what would be the size difference from a 285/45/22 and a 285/40/22. I want to get the same tires I had on my SS Trailblazer but they only make them in a 285/45/22.
Old Mar 3, 2013 | 02:28 PM
CMil527's Avatar
CMil527
Which tires? Most manufacturers list all specs on their sites... Your looking for overall diameter!
Old Mar 3, 2013 | 07:49 PM
FSTDANGO3's Avatar
FSTDANGO3
The 285/45 are 32.467" in diameter 11.63" wide
the 285/40 are 31.304" in diameter 11.63"wide
here is the known formula by tire manufacturers
Take first # divide that by 24.5=tire width, then take that number multiply by aspect ratio that=sidewall height. add sidewall height x 2 + rim diameter for overall diameter.
ex: 285/24.5=11.632, 11.63 x .40 = 4.652", 4.652" x 2 = 9.304" + 22"(rims) = 31.304"
Every manufacture is slightly different but this will keep you on track
STEVE
Old Mar 3, 2013 | 08:38 PM
CMil527's Avatar
CMil527
Fancy formula!!
Old Mar 3, 2013 | 08:42 PM
FSTDANGO3's Avatar
FSTDANGO3
Cool
I used it so many times when calculating tires on my old D
In 78000 miles i changed tires 10 times lol
Old Mar 4, 2013 | 01:51 PM
mac424's Avatar
mac424
These guys are spot on with their feedback. I'll offer a website I found that you can use to overlay your current tire over the new proposed tire size. It works really well!
http://www.tacomaworld.com/forum/tirecalc.php
