3rd Gen Durango 2011+ models
Startup and shuts off, no tuner on.
Old May 28, 2013 | 08:38 AM
rrjjpp74's Avatar
rrjjpp74
Default Startup and shuts off, no tuner on.
I know some people have had issues with start and shut down that have the Hypertech tuner, but I DON"T have the tuner. I will start up my Durango and it will shut right off. Then I go to try to start it back up and it just cranks and cranks. I finally stop it and then let it sit a few and try again to start and it runs. Has happened to me 3 times recently. Has anyone seen this and any resolution?
Old May 28, 2013 | 10:34 AM
FSTDANGO3's Avatar
FSTDANGO3
Please god no...don't tell me problems are starting with the 13's
Old May 28, 2013 | 11:46 AM
rrjjpp74's Avatar
rrjjpp74
Yeah this is the 3rd time in past 2 weeks it has happened to me. Called dealer and dropping it off tonight. Only got 6k on it.
Old May 28, 2013 | 01:28 PM
FSTDANGO3's Avatar
FSTDANGO3
Keep us posted!
Old May 28, 2013 | 02:11 PM
CMil527's Avatar
CMil527
straight to the dealer!
Old May 28, 2013 | 07:56 PM
SS2RT's Avatar
SS2RT
i have a '13 with almost 7K miles...
so far only happened with remote start where it has shut back off, and I only use that occasionally..
Good luck - let us know..
Old May 29, 2013 | 03:17 AM
IEWRX's Avatar
IEWRX
I doubt anything changed between the 11 and 13 as far as the TIPM and connections go. One person on here just had the TIPM just replaced and they are reporting it was happening again.
Dodge really needs to look into this. THe line from the dealer that did mine was "nevewr seen this before". Even though I talked to the tech that said he had. Dodge don't cover it up, find a fix that works. So far since mine was replaced, I have not had another issue....
Old May 29, 2013 | 07:06 AM
rrjjpp74's Avatar
rrjjpp74
IEWRX,
What is the TIPM? And was they able to diagnose this thru a scan tool or how?
Old May 29, 2013 | 07:35 AM
FSTDANGO3's Avatar
FSTDANGO3
Think of it as an interactive module for the whole car. It handles everything including security features etc. Your symptoms indicate that the TIPM is thinking the car is being stolen. When this system feels the car is being stolen it will start /run / shut down then Crank and crank.
As someone else stated they have to get these TIPM modules sorted out. Other models are having worse problems because of them and not just Dodge, other manufacturers just call them different names.
STEVE
Old May 29, 2013 | 07:50 AM
FSTDANGO3's Avatar
FSTDANGO3
I am pretty close with the dealership I use and they said the same thing...Zero failures on the Jeeps and Durangos 12-13 TIPM's.
2014 Jeeps and rams a few problems with new radio system and it's interaction with the TIPM.
We will see
STEVE
