3rd Gen Durango 2011+ models
Annoying Seatbelt Chime!
Old Nov 4, 2013 | 10:28 PM
balentinetire's Avatar
balentinetire
Default Annoying Seatbelt Chime!
I just purchased a new 2014 Durango and I am wondering how I would go about disabling the seatbelt chime, it is absolutely irritating.
Before anyone posts that I shouldn't be worrying about disabling it because I should wear it I have heard it all already. It is a choice and I choose not to so if someone can please help me it would be greatly appreciated.
Old Nov 5, 2013 | 12:14 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
It is a federal law and I would assume the chime can not be altered. I will move this th the correct section.
FF
Old Nov 5, 2013 | 12:18 PM
Gqjeff's Avatar
Gqjeff
On my old Touareg I was able to disable mine with my vag com tool. I am sure if you had the scanner tool you could do it.
Old Nov 5, 2013 | 01:11 PM
djibara's Avatar
djibara
Check your manual on my 2005 dakota I was able to turn off the seatbelt chime. Also there is a sticky here somewhere
Old Nov 5, 2013 | 01:41 PM
fishandgrits's Avatar
fishandgrits
Yeah, in my 2011 RAM all you had to do was turn the key to the run position without cranking, then buckle and unbuckle 10 times in 1 minute and viola, no more chime! Not sure if this works in the Durango though. I'll give it a try tonight and see.
Thanks for posting this, you reminded me I need to do the same.
Old Nov 5, 2013 | 03:57 PM
dakotaff's Avatar
dakotaff
According to your owners manual:
BeltAlert® can be enabled or disabled by your authorized
dealer. Chrysler Group LLC does not recommend
deactivating BeltAlert®.
Looks like you can't disable it yourself.
Old Nov 5, 2013 | 05:08 PM
MJNewman's Avatar
MJNewman
Or just order a belt insert.
Old Nov 5, 2013 | 06:24 PM
dakotaff's Avatar
dakotaff
I never knew those damn things existed, problem solved!
Old Nov 5, 2013 | 06:59 PM
detailsbyfrank's Avatar
detailsbyfrank
They sure do.
I have been eyeballing them for a month now.
Here you go:
http://www.ebay.com/itm/For-Dodge-Car-Logo-Emblem-Seat-Belt-Buckle-Alarm-Safety-Clasp-Stop-Canceller-/221309122515?pt=Motors_Car_Truck_Parts_Accessories&fits=Make%3ADodge&hash=item33870d37d3&vxp=mtr
Old Nov 5, 2013 | 08:22 PM
Fullslp's Avatar
Fullslp
Measure the resistance between the two wires that travel to the buckle the third is a ground. Then buy a resistor at radio shack of the sane resistance for less than a buck. Install between lead wire and PCM wire and bingo! No more chime.
