Foglight issue
So, i ran hids in my fogs for a while, switched back to regular bulbs. Went to put hids back in. Did the driver side, powered it up. Lit up great.
Did the passenger, turned it on, they lit up for 1/2 second, then both went out and i no longer have power to them. No error lights on dash. Cant find a fuse for them and didnt see any blown.
Any ideas?
Any ideas?
I checked the wiring diagram and it's not much help.
https://techauthorityonlinedemo.extr...ew/classic.htm
It says there is a 60 amp fuse and a circuit board, but it doesn't have info on the location of the fuse EXCEPT for the words INLINE JMP POST TO HDLP DASH. It also has a dotted line around the fuse which is supposed to mean that it is internal to a module or junction block. There is a non-serviceable circuit board attached the fuse. I remember in my Gen 1 SLT that the headlight switch would sometimes burn out because of the fog lamps being controlled by it. Anyway, you can look at the diagram yourself by plugging your car details. Good luck.
Trending Topics
