3rd Gen Durango 2011+ models
How many tires do I have to replace?
Old May 26, 2014 | 06:23 AM
Pdwelch2000's Avatar
Pdwelch2000
Default How many tires do I have to replace?
I damaged the front drivers tire. Cut the sidewall, so it is done. Tires have 9,800 miles on them.
The have heard AWD requires all 4 tires to be replaced...Dodge manual says replace in pairs. But not sure if that is the case for the AWD or 2WD
I am worried more about the AWD system and possibly causing a problem due to 2 tires being one diameter and the 2 new ones a different diameter.
Please let me know your thoughts. I know there are a lot of you out there with the working knowledge of the transmission and transfer case.
Vehicle is a 2014 R/T AWD.
Thank You!
Old May 26, 2014 | 06:31 AM
RDuck's Avatar
RDuck
9800 is nothing.
Replace the one.
If worried have the others measured. You'll find they should be like new anyways.
Old May 26, 2014 | 10:20 AM
Wash Man's Avatar
Wash Man
Originally Posted by RDuck
9800 is nothing. Replace the one. If worried have the others measured. You'll find they should be like new anyways.
Agreed
Old May 26, 2014 | 10:47 AM
Fullslp's Avatar
Fullslp
No worries at all bro. The difference between a worn tires diameter is so insignificant it won't alter the AWD system at all. Plus if your running stock tires the tread wear rating is phenomenal. I blew a tire with 8400 miles and had almost 90% tread left.
Old May 26, 2014 | 07:53 PM
JRRF's Avatar
JRRF
Originally Posted by Wash Man
Agreed
Ditto!
Old May 29, 2014 | 11:06 AM
IlliniJeeper's Avatar
IlliniJeeper
The stock tires have a diameter of 30.5". Assuming that they have 90% tread life left, the difference in diameter between a new tire and your other tires would be about 3/64" (~.05"). If your new tire was spinning at 60 mph, your worn tires would be spinning at 59.9 mph. Not a problem for your AWD system.
Old May 29, 2014 | 02:42 PM
FSTDANGO3's Avatar
FSTDANGO3
X6 only need one right now
STEVE
Old May 29, 2014 | 03:32 PM
djbucky3's Avatar
djbucky3
To sound like a beautiful to your hears broken record. Just buy one
Old May 30, 2014 | 02:34 PM
Pdwelch2000
I put just one on. Very happy.
