3rd Gen Durango 2011+ models
Recall
Old May 30, 2014 | 11:35 PM
Auggie360's Avatar
Auggie360
Default Recall
Received two recalls today for 2011/2014 Durango, Jeep and Grand Cherokee vehicles regarding the brake booster. One was for my truck and I have no idea who should get the other one that was sent to me by mistake? The vin on that truck is #DC565815.
Auggie
Old Jun 2, 2014 | 09:25 PM
master tech's Avatar
master tech
Site Moderator & Tech
Safety Recall P14 / NHTSA 14V-154
Brake Booster
2011 - 2014 (WD) Dodge Durango
(WK) Jeep Grand Cherokee
NOTE: This recall applies only to the above vehicles built through September 08, 2013 (MDH 090804).
The brake booster on about 639,000 of the above vehicles may prematurely corrode. If perforation of the brake booster shell (due to corrosion) occurs, the brake booster may ingest water during vehicle operation in wet weather conditions.
A brake booster that has experienced water ingestion may have the brake function compromised if the water inside the brake booster freezes. The driver may be required to apply additional application force to apply the brakes during sub-freezing driving conditions. An unexpected additional brake pedal application force requirement could slow the driver’s brake application reaction time and cause a crash without warning.
All involved vehicles must have the brake booster inspected for corrosion. Brake boosters found with excessive corrosion will be replaced. All boosters will be equipped with a shield to protect the brake booster crimp joints from water exposure. Models IMPORTANT: Some of the involved vehicles may be in dealer used vehicle inventory. Dealers should complete this recall service on these vehicles before retail delivery. Dealers should also perform this recall on vehicles in for service. Involved vehicles can be determined by using the VIP inquiry process. Subject Repair
Safety Recall P14 – Brake Booster Page 2
Dealers should attempt to minimize customer inconvenience by placing the owner in a loaner vehicle if inspection determines that brake booster replacement is required and the vehicle must be held overnight.
Part Number Description
CBXNP143AA Water Shield, Brake Booster (includes two master cylinder retaining nuts)
CBXNP141AA Booster, Brake
CBXNP142AA Brake Booster Installation Package
Each package contains the following components:
Quantity Description
4 Nut, Brake Booster-to-Dash Panel
2 Nut, Master Cylinder-to-Brake Booster
1 Clip, Brake Booster Rod-to-Brake Pedal
Due to the small number of involved vehicles expected to require brake booster replacement, no parts will be distributed initially. Brake booster packages should be ordered only after inspection determines that repair is required. Very few vehicles are expected to require brake booster replacement.
 NPN wiTECH VCI Pod Kit
 NPN Laptop Computer
 NPN wiTECH Software
Alternate Transportation Parts Information Special Tools
Safety Recall P14 – Brake Booster Page 3
A. Test Brake Booster
1. Connect wiTECH to the vehicle.
2. Start a wiTECH session.
3. Select “Preferences” at the top of the “Vehicle View” screen.
4. Change “Units of Measurement” to “Metric” and then click the “Apply” button.
5. Restart the wiTECH session.
6. Select “ABS” icon from the vehicle view screen.
7. Select “Data” tab.
8. Monitor the “Vacuum Sensor” value on the wiTECH list (Figure 1). Service Procedure
Figure 1 – wiTECH Data Screen
Safety Recall P14 – Brake Booster Page 4
9. Start the engine and allow it to idle for two minutes.
10. Record the vacuum reading with the engine running.
11. Turn off the vehicle and place the vehicle in the accessory position within 5 seconds and record the vacuum reading.
12. Wait 55 seconds and record the vacuum reading:
 If the vacuum reading has not changed by more than 40 millibars (mbars), the brake booster is good. Continue with Section B. Install Brake Booster Foam Shield.
 If the vacuum reading changes by more than 40 millibars (mbars), the brake booster is defective. Continue with Section C. Replace Brake Booster.
Service Procedure
Safety Recall P14 – Brake Booster Page 5
1. With the engine not running and the ignition OFF, pump the brake pedal until a firm pedal is achieved (4-5 strokes).
CAUTION: Vacuum in brake booster must be pumped down before removing the master cylinder from the brake booster. This is necessary to prevent the master cylinder primary piston from being pulled out of the master cylinder as the master cylinder is separated from the brake booster. This can be done by pumping brake pedal, with vehicle engine not running and the ignition OFF, until a firm feeling brake pedal is achieved.
2. Disconnect the negative battery cable at the battery.
3. For vehicles with a 5.7L engine, remove and save the engine cover.
4. For vehicles with a 5.7L engine, remove and save the air inlet hose resonator (Figure 2).
5. Remove and save the air cleaner assembly (Figure 2).
6. Relocate the power steering reservoir (Figure 3). Service Procedure (Continued)
Figure 2 – Intake Air Resonator
Figure 3 – Relocate Power Steering Reservoir
AIR CLEANER ASSEMBLY
AIR INLET HOSE RESONATOR
POWER STEERING RESERVOIR
Safety Recall P14 – Brake Booster Page 6
7. Remove and save the cowl seal (Figure 4).
8. Remove and save the left side cowl extension panel (Figure 4).
9. Remove and save both windshield wiper arms.
10. Remove and save the plastic cowl cover (Figure 5).
CAUTION: There are three clips on each end of the cowl cover. Use care not to break them during removal (Figure 5). Service Procedure (Continued)
Figure 4 – Cowl Seal
Figure 5 – Cowl Cover Clips
COWL SEAL
LEFT SIDE COWL EXTENSION PANEL
PLASTIC COWL COVER
COWL COVER CLIPS
Safety Recall P14 – Brake Booster Page 7
11. Disconnect the vacuum sensor electrical connector.
12. Disconnect the master cylinder brake fluid sensor electrical connector.
13. Disconnect the wiring harness retaining clip at the shock tower.
14. Disconnect the vacuum hose and check valve from the brake booster (Figure 6).
15. Remove and discard the master cylinder mounting nuts.
16. Unclip the brake tube support on the left shock tower (Figure 7).
Figure 6 - Brake Booster Check Valve
Figure 7 – Brake Tube Support
VACUUM SENSOR AND CHECK VALVE
VACUUM SUPPLY HOSE
BRAKE TUBE SUPPORT
LEFT SHOCK TOWER
Safety Recall P14 – Brake Booster Page 8
17. Carefully relocate the master cylinder (Figure 8).
CAUTION: Use extreme care not to damage the brake tubes when relocating the master cylinder.
CAUTION: Use extreme care not to scratch or damage the master cylinder piston (Figure 9). Service Procedure (Continued)
Figure 8 – Relocate Master Cylinder
Figure 9 – Master Cylinder Piston
MASTER CYLINDER RESERVOIR
MASTER CYLINDER
BRAKE TUBES
MASTER CYLINDER PISTON
MASTER CYLINDER
Safety Recall P14 – Brake Booster Page 9
18. Cover the brake booster openings with masking tape to prevent debris from entering the brake booster (Figure 10).
19. Using glass cleaner, clean the brake booster surface area where the foam seal contacts the brake booster.
20. Using glass cleaner, lubricate the inside surface of the brake booster foam shield (Figure 11).
Figure 10 – Cover Brake Booster Openings
Figure 11 – Lubricate Brake Booster Foam Shield
MASKING TAPE
BRAKE BOOSTER
BRAKE BOOSTER FOAM SHIELD
Safety Recall P14 – Brake Booster Page 10
21. Install the brake booster foam shield onto the booster with the locating tabs at the three and nine o’clock positions. The tabs ends should be flush with the edge of the booster (Figure 12).
22. Pull the brake booster foam shield tabs back slightly and remove the release paper and press the tab against the side of the brake booster.
23. Place the master cylinder into position and install new retaining nuts. Tighten the nuts to 18 ft. lbs. (25 N·m).
24. Install the wire harness retaining clip to the left shock tower.
25. Clip the brake tube support to the left shock tower (Figure 7).
Figure 12 – Correctly Installed Brake Booster Foam Shield
SHIELD TAB END FLUSH WITH BOOSTER
TABS AT 3 AND 9 O’CLOCK POSITION
Safety Recall P14 – Brake Booster Page 11
26. Connect the brake booster check valve and vacuum hose (Figure 6).
27. Connect the vacuum sensor electrical connector.
28. Connect the master cylinder brake fluid level sensor electrical connector.
29. Install the plastic cowl cover (Figure 5).
30. Install both wiper arms. Tighten the wiper arm retaining nuts to 16 ft. lbs. (21 N·m).
31. Install the left side cowl extension panel (Figure 4).
32. Install the cowl seal (Figure 4).
33. Place power steering reservoir into position and install retaining bolt (Figure 3).
34. Install the air cleaner assembly.
35. For vehicles with a 5.7L engine, install the air inlet hose resonator (Figure 2).
36. For vehicles with a 5.7L engine, install the engine cover.
37. Connect the negative battery cable to the battery.Service Procedure (Continued)
Safety Recall P14 – Brake Booster Page 12
NOTE: The following procedure is required if the brake booster requires replacement per the test in Section “A.”
5. Remove and save the air cleaner assembly.
13. Disconnect the wiring harness retainer at the shock tower.
14. Disconnect the vacuum hose and check valve from the brake booster (Figure 6). Service Procedure (Continued)
Safety Recall P14 – Brake Booster Page 13
15. Remove and discard the master cylinder retaining nuts.
CAUTION: Do not disconnect the brake tubes from the master cylinder and use extreme care not to damage the brake tubes when relocating the master cylinder.
18. Remove and save the wiper motor and linkage as an assembly.
19. Remove and save the instrument panel lower silencer cover (Figure 13).
20. Remove and discard the brake pedal pivot pin-to-brake booster push rod retaining clip.
21. Separate the brake booster push rod from the brake pedal pivot pin.
22. Loosen the brake light switch bracket and relocate.
23. Remove and discard the four brake booster retaining nuts (Figure 14). Service Procedure (Continued)
Figure 13 – Instrument Panel Lower Silencer
Figure 14 – Brake Booster Retaining Nuts
INSTRUMENT PANEL LOWER SILENCER PANEL
HOOD RELEASE LEVER
BRAKE BOOSTER RETAINING NUTS
BRAKE PEDAL ARM
Safety Recall P14 – Brake Booster Page 14
24. Remove and discard the original brake booster.
25. For new brake boosters without a foam shield, install a foam shield (Figure 22).
26. Lubricate the brake pedal pivot pin with Mopar multi-mileage grease.
27. Install the new brake booster into position.
28. Install four new brake booster retaining nuts and tighten them to 15 ft. lbs. (20 N·m).
29. Place the brake booster push rod onto the brake pedal pivot.
30. Install a new brake pedal pivot pin-to-brake booster push rod retaining clip. Service Procedure (Continued)
Figure 15 – Remove Brake Booster
BRAKE BOOSTER
MASTER CYLINDER
Safety Recall P14 – Brake Booster Page 15
31. Install the instrument panel lower silencer cover (Figure 13).
32. Install the wiper motor and linkage assembly. Tighten the mounting bolts to 55 in. lbs. (6 N·m).
33. Place the master cylinder into position and install new retaining nuts. Tighten the nuts to 18 ft. lbs. (25 N·m).
34. Install the wire harness retaining clip to the left shock tower.
35. Connect the brake tube support to the left shock tower (Figure 7).
36. Connect the brake booster check valve and vacuum hose (Figure 6).
37. Connect the vacuum sensor electrical connector.
38. Connect the master cylinder brake fluid level sensor electrical connector.
39. Install the plastic cowl cover (Figure 5).
40. Install both wiper arms. Tighten the wiper arm retaining nuts to 16 ft. lbs. (21 N·m).
41. Install the left side cowl extension panel (Figure 4).
CAUTION: Make sure the left side cowl extension panel tab is properly snapped into place.
42. Install the cowl seal (Figure 4).
43. Place power steering reservoir into position and install retaining bolt (Figure 3).
44. Install the air cleaner assembly.
45. For vehicles with a 5.7L engine, install the air inlet hose resonator (Figure 2).
46. For vehicles with a 5.7L engine, install the engine cover.
47. Connect the negative battery cable to the battery.
Safety Recall P14 – Brake Booster Page 16
Claims for vehicles that have been serviced must be submitted on the DealerCONNECT Claim Entry Screen located on the Service tab. Claims submitted will be used by Chrysler to record recall service completions and provide dealer payments.
Use one of the following labor operation numbers and time allowances:
Labor Operation Time
Number Allowance
Test brake booster and install brake
booster foam shield 05-P1-41-82 0.9 hours
Test and replace brake booster and install
brake booster foam shield 05-P1-41-83 1.2 hours
Add the cost of the recall parts package plus applicable dealer allowance to your claim.
NOTE: See the Warranty Administration Manual, Recall Claim Processing Section, for complete recall claim processing instructions.
To view this notification on DealerCONNECT, select “Global Recall System” on the Service tab, then click on the description of this notification.
All involved vehicle owners known to Chrysler are being notified of the service requirement by first class mail. They are requested to schedule appointments for this service with their dealers. A generic copy of the owner letter is attached.
Enclosed with each owner letter is an Owner Notification postcard to allow owners to update our records if applicable.
Completion Reporting and Reimbursement Dealer Notification Owner Notification and Service Scheduling
Safety Recall P14 – Brake Booster Page 17
All involved vehicles have been entered into the DealerCONNECT Global Recall System (GRS) and Vehicle Information Plus (VIP) for dealer inquiry as needed.
GRS provides involved dealers with an updated VIN list of their incomplete vehicles. The owner’s name, address and phone number are listed if known. Completed vehicles are removed from GRS within several days of repair claim submission.
To use this system, click on the “Service” tab and then click on “Global Recall System.” Your dealer’s VIN list for each recall displayed can be sorted by: those vehicles that were unsold at recall launch, those with a phone number, city, zip code, or VIN sequence.
Dealers must perform this repair on all unsold vehicles before retail delivery. Dealers should also use the VIN list to follow up with all owners to schedule appointments for this repair.
Recall VIN lists may contain confidential, restricted owner name and address information that was obtained from the Department of Motor Vehicles of various states. Use of this information is permitted for this recall only and is strictly prohibited from all other use.
If you have any questions or need assistance in completing this action, please contact your Service and Parts District Manager.
Customer Services / Field Operations
Chrysler Group LLC Vehicle Lists, Global Recall System, VIP and Dealer Follow Up Additional Information
__________________________________________________ ____________________________________
IMPORTANT SAFETY RECALL P14 / NHTSA 14V-154
This notice applies to your vehicle (VIN: xxxxxxxxxxxxxxxxx).
This notice is sent to you in accordance with the requirements of the National Traffic and Motor Vehicle Safety Act.
Dear: (Name)
Chrysler has decided that a defect, which relates to motor vehicle safety, exists in some 2011 through 2014 model year Dodge Durango and Jeep® Grand Cherokee vehicles.
The problem is...
The brake booster on your vehicle may prematurely corrode. If perforation of the brake booster shell (due to corrosion) occurs, the brake booster may ingest water during vehicle operation in wet weather conditions.
What your dealer will do...
Chrysler will repair your vehicle free of charge (parts and labor). To do this, your dealer will test the brake booster, install a protective brake booster shield and/or replace the brake booster if required. The work will take about one hour to complete. However, additional time may be necessary depending on service schedules.
What you must do to ensure your safety...
Simply contact your Chrysler, Jeep, or Dodge dealer right away to schedule a service appointment. Please bring this letter with you to your dealer.
If you need help...
If you have questions or concerns which your dealer is unable to resolve, please contact the Chrysler Group Recall Assistance Center at 1-800-853-1403.
Please help us update our records by filling out the attached prepaid postcard if any of the conditions listed on the card apply to you or your vehicle. You may also update this information on the web at CCCCCCCCCCCCCCCCCCCCCCCCCC
If you have already experienced this condition and have paid to have it repaired, please send your original receipts and/or other adequate proof of payment to the following address for reimbursement: Chrysler Customer Assistance, P.O. Box 21-8007, Auburn Hills, MI 48321-8007, Attention: Reimbursement. Once we receive and verify the required documents, reimbursement will be sent to you within 60 days.
If your dealer fails or is unable to remedy this defect without charge and within a reasonable time, you may submit a written complaint to the Administrator, National Highway Traffic Safety Administration, 1200 New Jersey Ave., S.E., Washington, DC 20590, or call the toll-free Vehicle Safety Hotline at 1-888-327-4236 (TTY 1-800-424-9153), or go to http://www.safercar.gov.
We're sorry for any inconvenience, but we are sincerely concerned about your safety. Thank you for your attention to this important matter.
Chrysler Group LLC
Note to lessors receiving this recall: Federal regulation requires that you forward this recall notice to the lessee within 10 days.
BRAKE BOOSTER
Old Jun 2, 2014 | 09:35 PM
FSTDANGO3's Avatar
FSTDANGO3
I know mine has no corrosion it hasnt been out in the Rain for any extended period of time or in snow at all this winter.
WHat does this shield look like in place master tech?
Have you seen any yet?
STEVE
Old Jun 3, 2014 | 04:24 PM
Whiteout08's Avatar
Whiteout08
I experienced this failure over the weekend, and almost got into a serious accident. As of yesterday, the Durango is GONE...can't have that type of issue and feel comfortable ever driving it again, even if it gets "fixed".
Old Jun 3, 2014 | 10:10 PM
MIKEon22s's Avatar
MIKEon22s
Got my recall, looks like the AFE has to come off so they can do the recall. I'd be surprised to pass as this is how mine looked every weekend Dec-April. 500-600 round trip every weekend.
Old Jun 3, 2014 | 11:26 PM
JustinK.'s Avatar
JustinK.
Nice wheels on trailer!! What ya ride?
Old Jun 4, 2014 | 10:45 AM
MIKEon22s's Avatar
MIKEon22s
Skidoo 900's Renegades , thanks
Old Jun 4, 2014 | 10:53 AM
DDCREW's Avatar
DDCREW
STEVE
Check this link:
http://www.wk2jeeps.com/tsb/rc_P1414.pdf
It is the .pdf version of what master tech described and it has pictures. Looks like one of those "lamp shade" cones that they put on cats/dogs to prevent them from reaching injuries, rashes, etc. They have to remove the booster to mount this shield.
Old Jun 4, 2014 | 01:08 PM
FSTDANGO3's Avatar
FSTDANGO3
That is a lot of work just to install that
STEVE
Old Jun 4, 2014 | 06:27 PM
Fullslp's Avatar
Fullslp
STEVE
Holy Crap.... What Steve said^^^ I think I'll make my own foam shield and they can keep there dirty hands out of my engine compartment. It seems like they could have come up with split design allowing the foam strip to be placed around the booster and a locking strap to keep it in place. It's only there to keep water out not hold the booster together.
