3rd Gen Durango 2011+ models
had my first No Start this morning (TIPM)
Old Dec 5, 2014 | 04:24 PM
2011CrewLuxSC's Avatar
2011CrewLuxSC
Originally Posted by roogie
Took mine to the dealer this morning for non-starting issue (V6 engine). Mine would eventually start after doing 3-4 cycles of the OFF-ACC-RUN trick. All ready to pick up at Overland Park Jeep/Dodge, faulty fuel pump relay, now externally bypassed.
roog
excellent. I admit to being a little jealous. no parts available in my area yet. at least not that anyone is willing to tell me.
the byapss is working good though.
Old Dec 6, 2014 | 01:55 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
I got another one yesterday...pfft, I can't make heads or tails of the logic. One day there are none to be had, next day one hits the door.
Old Dec 6, 2014 | 11:21 AM
roogie's Avatar
roogie
My receipt shows a parts list that appears to be similar to the VerticalVision's offering. After sitting overnight it fired right up this morning.
roog
Old Dec 7, 2014 | 01:55 PM
coldsteel's Avatar
coldsteel
Cross thread post: https://dodgeforum.com/forum/3rd-gen...ml#post3212506
I was told by my dealer that no parts were available and there is/was no ETA. Pre-emptively, I ordered the relay kit on Amazon, using the StarCase that has been published here.
As of last Friday, my 2011 became stranded in my garage. It had been acting up since the weather turned colder, so the wife and I kept parking it nose first into the garage so when it finally quit, I could work on it.
I just completed the procedure and wouldn't you know, she fired right up! I would guess the skill level is about a 6/10 depending on your comfort with tight quarters, dozens of wires, and cutting some pretty important factory wiring out of the harness.
Chrysler gives the procedure 1.0 hour - I took about 3 hours. I went slow and deliberately through the procedure before and during each step. I also kept my multimeter handy to verify continuity at every splice before continuing.
I just couldn't see having my DD towed out of my garage to my servicing dealer (17 miles) just for it to sit because there are no parts. I paid good money for this vehicle and I plan on keeping it for the long haul so ~$60 out of pocket was worth it to me.
Old Dec 7, 2014 | 03:23 PM
2011CrewLuxSC
coldsteel, I totally applaud you for taking the initiative and fixing the D. way to go. I was heading down that path until I found Jason's (at Vertical Visions) plug in bypass.
for anyone that does not want to cut into their D's wiring harness but needs this fixed, NOW, I can't say enough good about the $26 plug and play bypass that Jason sent me.
but if I hadn't found Jason's bypass I'd be doing exactly what you did. I looked up the Star Case pdf and went searching online for the relay. its amazing how common it is and easy to find on the internet. I had one in my cart, ready to pull the trigger when I came across Jason's plug in solution.
I even called the Service Mgr at my local Dodge dealer, whom I find to be a pretty good guy so far, and said 'look, I'll bring in the part, just fix it.' but I posted that story earlier in the thread.
good for you coldsteel. I hope your D starts like a champ from now on.
Old Dec 26, 2014 | 05:18 PM
2011CrewLuxSC
had my TIPM bypass done on the recall today. the dealer took care of the P54 recall along with the Brake Booster and the Visor wiring fix. took about 2.5 hours altogether. everything seems to be working; no issues with fogs or anything else I notice.
the recall fix is the same basic external relay and fuse holder installed outside the fuse/relay box and mounted on a clip near the front of the engine bay.
I did notice a couple electronic things had been 'reset'. I had my red glow trim rings around the speedo and tach turned off and they were turned back on and my 430N has a new splash screen that I swear wasn't there before. but no big deal.
Old Dec 28, 2014 | 05:05 PM
zimmer54's Avatar
zimmer54
Just happened to my 2011D R/T 35,000 miles last week, Called dealer here in Phoenix and taking it in Tomorrow, They told Me they have the parts for both Brake and Tipm
Recall, Bad part they will need it for 2 days, Wife is on vacation so I will have a car.
Will let all know what the out come is.
Old Dec 28, 2014 | 07:23 PM
FSTDANGO3's Avatar
FSTDANGO3
Good deal that they are fixing it pronto
STEVE
Old Dec 29, 2014 | 09:14 PM
zimmer54's Avatar
zimmer54
Default Recall's Done
Well got 2011 D R/T Awd back tonight,Brake recall, They install Shield.
Visor recall, Replaced Visor, Tipm recall, Did bypass on Fuel Pump Relay.
Was 4 Flashes Software Update's, Not sure want they did.
PCU Flashes, PEM?, SAS?, DTCM?, PLGM?
Does anyone know what this is for? Service advisor did not know.
All took from 8:AM to 5:00Pm, Had to pay for Flashes $130.00 my D
is out of warranty.Labor cost's work time to complete, Brake .90, Visor 1.3,
Fuel P Relay .70, Hope this help's the group out here.
Walt
Old Dec 29, 2014 | 10:36 PM
FSTDANGO3's Avatar
FSTDANGO3
They charged for the software updates...That is BS
STEVE
