3rd Gen Durango 2011+ models
Recalls
Old 12-01-2015, 05:23 PM
Crankshaft57's Avatar
Crankshaft57
Crankshaft57 is offline
Default Recalls
Well, I finely brought my 2012 Durango Crew 5.7L to the Dealership to have the three recalls done. When I got home and shut the engine off the Easy Entry/Exit seat did nothing. I got out my Owners Manual and tried many times to reprogram the seat with no luck. Has anyone had this problem and could this be related to the fuel pump relay mod? Also they said that they did the brake booster recall but when I looked at the booster there was still dust on it as if it had never been touched. Does anyone have a pic as to what the booster should look like after the recall is done? Thanks
Auggie
Old 12-02-2015, 09:34 AM
DodgeCares's Avatar
DodgeCares
DodgeCares is offline
I haven't heard of any easy entry/exit concerns being caused by the fuel pump relay recall repair, Auggie. Did it work properly when you entered your vehicle at the dealership? Was this the first time this has happened?
Old 12-02-2015, 11:15 AM
Crankshaft57
Yup, it sure did and yes this was the first time that this has happened. When I checked the truck in I shut off the engine and the seat and steering wheel did there thing. When I picked up the truck the seat was way back so I hit the #1 button and nothing happened. I then manually adjusted the seat and steering wheel ect and went home. In the garage I shut off the engine and nada nothing. I moved the seat back to get out. A few days later I tried to reprogram the seat. I got the #1 button to work only but not the rest. Any suggestions ??
Auggie
Old 12-02-2015, 11:36 AM
coldsteel's Avatar
coldsteel
coldsteel is offline
Did you re-enable the easy entry/exit seat in the EVIC menu?
Old 12-02-2015, 04:44 PM
Crankshaft57
Yes I did.
Old 12-02-2015, 05:56 PM
jkeaton is offline
Dodge Forum Administrator
Might have to take it back and ask the dealer.
Old 12-02-2015, 10:38 PM
roogie's Avatar
roogie
roogie is offline
Mine stopped doing the exit thing once (2011 AWD Crew) and I ran the seat all the way back, then all the way forward and reset my presets (1 and 2) and it started working again.
roog
Old 12-03-2015, 10:26 AM
DodgeCares's Avatar
DodgeCares
If roogie's suggestion doesn't work, I would suggest taking your Durango back to the dealership that performed the repair to check with them about this.
Old 12-03-2015, 12:34 PM
Crankshaft57
OK, Roogie I will try that and get back to you. Yup, DC I already have an appointment for 12/09/15 at the original Dealership. Thanks.
Auggie
Old 12-03-2015, 07:52 PM
Claus Graf's Avatar
Claus Graf
Claus Graf is offline
Default Brake Booster Recall
Check your brake booster and see if it has a black foam type tape around (where the two halves lock together).
Quick Reply: Recalls
