Recalls
OK, Roog told me to move the drivers seat all the way back then all the way forward to get my EasyEnter/Exit seat to operate again. I tried it with the ign. in the Acc position and in the run position with no luck so I gave up and went into the house. Now I know this is no safety issue but its bugging me and I am blaming the Dealer for this problem. About an hour later the bulb goes off and I go back out to the garage and with the ign. in the off position I move the seat all the way forward and then all the way back (just the reverse of what Roog said to do) and leave it there. Then I am thinking that the Tech must of disconnected the batt. to do the relay recall. So I go back out to the garage and get into the truck and put the ign. in the run position and have the wife call me to see if the Bluetooth is working and it is "Not" so now I know that the Tech did in fact disconnect the batt. I push the #1 button to move the seat forward and I start the engine and have the wife try Bluetooth again and it still doesn't work. So I shut off the engine and lo and behold the EasyEnter/Exit system works. I would at this time like to THANK Roog. Thanks Pal!!
Auggie
Auggie
