3rd Gen Durango 2011+ models
Windshield vibration
Old Mar 1, 2016 | 09:55 PM
JMGold51's Avatar
JMGold51
Default Windshield vibration
Can anyone please explain this noise? Sorry if answered somewhere already I'm new to site.
Old Mar 2, 2016 | 09:01 AM
pjw1967's Avatar
pjw1967
I had a bad blower motor which the dealer finally replaced. Noise was not nearly as loud as yours. Does it occur all the time? Have you turned the climate control and/or radio on/off to see if any change? Does it happen at all speeds?
Old Mar 2, 2016 | 10:45 AM
coldsteel's Avatar
coldsteel
The speaker is loose underneath the center speaker grille or the windshield washer line under the hood is vibrating against the hood hinge
Old Mar 2, 2016 | 01:43 PM
Senpro's Avatar
Senpro
Have a similar noise as well. When it happens it's usually on a rough section of the road. I think it's coming from that vented plastic insert on top of the dash. When I put my finger on it, it stops.
Had a very unfavorable experience with a Subaru dealership and dash noises on a 13 Outback. Would rather try to solve this myself.
Old Mar 2, 2016 | 03:15 PM
DodgeCares's Avatar
DodgeCares
As pjw1967 suggested, you could try turning a few things on/off to see if it changes the noise to help isolate it. I see you have a 2015, are you still under the factory warranty from a mileage standpoint? If so, this would be best diagnosed by a FCA dealership.
Old Mar 2, 2016 | 05:43 PM
JMGold51's Avatar
JMGold51
Thanks for response. Only occurs when going speeds of 75mph or higher. I've tried turning everything on and off. Sound still occurs.
Old Mar 3, 2016 | 07:39 AM
JMGold51's Avatar
JMGold51
Ok I'll look at both. Did you have a similar issue?
Old Mar 3, 2016 | 08:34 AM
coldsteel's Avatar
coldsteel
There was a TSB for the washer line and a rattling hood hinge. I didn't have a speaker problem, but there have been some where the screws weren't torqued right and the vibrations backed them out.
Old Mar 3, 2016 | 04:51 PM
JMGold51's Avatar
JMGold51
On the 2015? I just checked a list and couldn't find it
Old Mar 4, 2016 | 05:53 AM
coldsteel's Avatar
coldsteel
No. On the 2011s, but the design didn't change that much so the same manufacturing issues can still occur.
