30K mile service on '14 Durango, AWD transfer case service
Took my DD to the dealer for an oil change and a few other things. They recommended 3 services:
1) power steering fluid service $165
2) brake fluid service $165
3) AWD/transfer case fluid service $450
Are you guys doing these services? I think I can trust a cheaper shop the do the 1st two, but the 3rd one seems like I should stick with the pros.
Not needed, that's what.
Page 162
https://www.google.com/url?sa=t&sour...MDX2DWTY3BgP3g
Transfer case fluid inspection, but not change. Change comes at 120,000. Not at 30k. As for brake fluid and power steering, no, not even listed. And that makes sense because neither of those should need changing unless there is contamination or leakage.
humyz,
Because brake fluid is hydroscopic, most recommend to flush/replace the brake fluid when new brakes are installed.
There is nothing about power steering fluid service in the owners manual and the transfer case and transmission fluids are scheduled for 120K miles. Now there is "Inspect transfer case fluid" at 30K, but $450 is a ripoff.
By the way, since you have a Hemi, did they state to perform spark plug replacement? My 2013 manual states spark plug replacement at 30K miles regardless of time passed.
NO...NO....and NO
PS flush is shameful. Brake fluid is especially shameful. Run far from that dealer.
humyz,
As for brake fluid normal brake jobs (pads and rotor replacement) don't need brake fluid flushing. Only if you remove the brake lines for some reason (caliper replacement for instance) would a brake fluid flush be recommended.
In any event, this dealer is taking the op to the cleaners.
Trending Topics
I've bought all the fluids myself using best prices through AutoZone/Advanced Auto and handed them to my local shop who had no problem using them and performing the service. I believe as long as you keep records (oil receipts if you perform your own oil changes) etc... you should be fine.
Jerry
