3rd Gen Durango 2011+ models
2011 durango crew with pushbutton start malfunction
Old Dec 1, 2017 | 09:47 PM
jjolman's Avatar
jjolman
Default 2011 durango crew with pushbutton start malfunction
when i walk up the doors unlock.. i get in and it says push brake and press start..when i do nothing happens. i put in a new battery but it didnt help.. i'm immobilized but can get in or out ok. pressing start without brake does not give accessory access? what can i do?
Old Dec 1, 2017 | 11:14 PM
Have another key fob you can try?
Old Dec 2, 2017 | 12:07 AM
jjolman's Avatar
jjolman
No just bought it yesterday from my Dodge dealer and coincidentally the other one was lost but a new replacement is only a little over$220
All butts seem dead on the fob byt the proximity feature works fine. I popped off the button and plugged in the fob and it turns,like a regular key, but does nothing. The 2" display where the press start says "off in the lower right corner. And now the fob is trapped by the ignition switch and cannot be removed.
Old Dec 2, 2017 | 03:52 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Your Radio Frequency HUB is going batty. Did this used to be a Police Car?
Old Dec 2, 2017 | 08:14 AM
usmc1811's Avatar
usmc1811
As much as hate to suggest it, you might want to contact the FCA dealership where you purchased the vehicle.
I think the dealership owes you some help on your issue, since you just bought the vehicle.
Hopefully they will step up and help you without trying to charge you $$.
Let us know how it goes.
Old Dec 2, 2017 | 11:19 AM
jjolman's Avatar
jjolman
I pulled the #27 fuze for a couple of minutes,. Replaced it ,. Now it's back to normal....thank...
Old Dec 5, 2017 | 10:46 AM
Prospect62's Avatar
Prospect62
What's that for and where did you get the idea to try it?
Old Dec 6, 2017 | 07:49 AM
SHO Rod's Avatar
SHO Rod
Interesting find. If that's fuse 10-amp M27 in the TIPM, that's the fuse for the Ignition switch, Wireless control module, and Keyless Entry Module.
-Rod
Old Dec 15, 2017 | 02:46 PM
SkipB's Avatar
SkipB
This happened to my wifes T+C and it ended up being a bad (car) battery!
