3rd Gen Durango 2011+ models
Transmission problem
Old Dec 9, 2017 | 07:12 PM
Duane Davis's Avatar
Duane Davis
Unhappy Transmission problem
  • 2005 Durango Limited w/tow pkg
  • 5.7 Hemi
  • AWD
  • 5-45RFE trans
  • 163K miles.
I've had the truck a few years. Never had any problems until now.
Driving up a hill (paved, not towing) suddenly it's like the trans has been shifted into neutral. No gears work (forward or reverse).
  • Shift selector moves normally.
  • Trans is whining. Sounds like a power steering pump that's low on fluid.
  • Fluid level is good.
  • Fluid looks and smells normal. red, not burnt.
  • No external leaks.
  • RTV instead of gasket so probably first tiime it's been apart.
  • No metal fragments in pan. Just a bit of fine metal "sludge" on the magnet. Looks clean otherwise.
  • Both filters in place and tight.
  • No loose bolts or other parts that I can see.
  • Removed valve body. I don't see anything abnormal
I have some experience rebuilding older Chrysler transmissions (727) but this is the first electronic one I've worked on.
Is there anything else I can check without dropping the trans?
I'm getting too old for this but can't afford to pay someone else to do it. Rebuilding it is easy. It's the removal and re-install that's the killer.
Any help would be greatly appreciated.
Duane
Old Dec 10, 2017 | 02:17 AM
fca tech's Avatar
fca tech
2 things come to me but both involve removing the pan 1st is the main filter goes directly into the bottom of the pump I have seen them fall out and cause a pressure loss second thing is on the side of the valve body is an accumulator cover the bolts like to break off if you remove the pan you should be able to see this
Old Dec 10, 2017 | 02:59 PM
Duane Davis
I've already pulled the pan, filters and valve body. Everything is where it's supposed to be. No loose hardware.
I did get the following code off it:
P0750 Shift Solenoid 'A'
P0700 Trans Control System
Old Dec 10, 2017 | 06:37 PM
fca tech's Avatar
fca tech
with the p0750 code which in Chrysler manual is P0750-LR SOLENOID CIRCUIT if it was in my shop I would be putting a solenoid pack in vehicle and both the filters to do this you have to remove the valve body which is only like 8 8mm bolts since you already have the pan off take valve body down then there's a lot of t25 bolts that hold the pack on attached are pictures of the bolts
Attached Thumbnails Transmission problem-808a2fb2-1-.gif   Transmission problem-808a2fc1-1-.gif
Old Dec 11, 2017 | 10:33 AM
Duane Davis
Thanks Brian. That supports my thoughts.
I already have the valve body out and the solenoid pack seperated. I checked the solenoids with an ohm meter and they check out but I know that's no guarentee that they will actually function. A remanufactured solenoid pack is under $150 so I figure it's a reasonable gamble.
Duane
Old Dec 11, 2017 | 11:02 PM
fca tech's Avatar
fca tech
the only thing I am concerned with is the whine when you install the main filter make sure the seal that goes into the pump is securely in place its #3 in the picture if your new filter comes with one don't install it on the filter first install it in the pump first then put your filter in it hope it works out ok for you let me know if it fixes it
Old Dec 26, 2017 | 12:14 PM
Luv2Q's Avatar
Luv2Q
I'm having a very similar issue with my 2006 Durango with the same configuration. I just replaced the solenoid pack and now the transmission won't shift into gear (reverse or drive). I'm not getting the whining sound that you are Duane. Were you able to get yours fixed?
