3rd Gen Durango 2011+ models
2015 Durango R/T - new owner
Old Sep 28, 2018 | 09:19 PM
RamedHemi's Avatar
RamedHemi
Exclamation 2015 Durango R/T - new owner
Hi all just bought my wife a nice black R/T fully loaded. Been looking for a year finally found one 100% loaded out. I am trying to put HID in the fogs and came across the problem of them shutting off when the truck is started. I read that a relay is needed. I see the battery is inside in truck, wasnt aware of that. Is there any place under the hood to get power to relay? i dont see it being worth running a wire all the way from the battery. If not maybe a good set of LEDs is better? Thanks!
Old Sep 28, 2018 | 09:27 PM
I think LED's might be a better plan..... the housing aren't really designed for HID.... they may melt......
Fogs should be on with the low beams only. If they aren't, (and they should be...) need to find out why.
Old Sep 28, 2018 | 11:13 PM
RamedHemi's Avatar
RamedHemi
hids work but when you start it up they go off, i read others with same issue. Fogs come on with parking lights as well.
Old Sep 29, 2018 | 12:27 PM
DDCREW's Avatar
DDCREW
There are battery + and - posts on the passenger side fender under the hood. Also, You should be able to find a wiring diagram showing the battery + wire going to the underhood fuse box a.k.a., by its fancy name, TIPM (Totally Integrated Power Module). On the other hand, you may be able to get LED's with built in adapters that just plug in into the existing bulb sockets.
Old Sep 29, 2018 | 12:28 PM
primem's Avatar
primem
there should be a positive post under the hood near the fuse box.
Old Sep 30, 2018 | 08:06 PM
RamedHemi's Avatar
RamedHemi
Has anyone else run HID in the fogs will the housing be able to handle the heat? Thanks
