View Poll Results: What CAI do you have or recommend?
K & N
245
35.66%
Air Raid
77
11.21%
AEM
25
3.64%
Mopar
36
5.24%
Volant
59
8.59%
Afe
32
4.66%
True Flow
7
1.02%
S & B
15
2.18%
Ram Hammer
9
1.31%
home made
113
16.45%
ebay or other (specify in a post)
69
10.04%
Voters: 687. You may not vote on this poll
Old Aug 5, 2015, 09:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Cold air intakes
Old Feb 11, 2011 | 08:56 AM
  #151
rocket23's Avatar
rocket23
Nice results...
Old Feb 21, 2011 | 07:29 AM
  #152
mitchn06's Avatar
mitchn06
i purchased a Spectre CAI last fall and so far have not been very impressed, mostly with fitment of the product. the air tube did not fit well at all and i could not even get it to bolt down where it was supposed to leading to it pulling out of the throttle body. FAIL! just this last weekend i built the Homeade pvc intake and it seems solid as all get out. just kind of bummed i bought a $150 air filter box. dang.....
Old Feb 22, 2011 | 07:08 AM
  #153
miketrock's Avatar
miketrock
Default Cheap, good quality filter ??
If I were to do the homemade CAI, what filter is reasonably priced to go along with that? I looked online at Autozone and they want $53 for a filter......just doesn't seem right if the pipe costs $5 to spend $50-60 for a filter.. Also, where can you get 3 1/2" pipe and fittings? At Home Depot by me they only have 3" & 4" ? The inside diameter of my TB is 3-3/16" (almost 3-1/4").....so 3" pipe would be a little restrictive. I'd rather have the whole pipe(about 3') a little big and the only restriction be the TB itself. Is there a kit to make any hoodscoops really work and bring in cool, filtered air?
Old Feb 22, 2011 | 04:56 PM
  #154
rocket23's Avatar
rocket23
In a word no. There isn't a hood with a built in filter. Spactre has a good universal one that you only buy once. 35.00 not too bad. Youclean it with a kit. every year, twice if your bogging regularly. I have since switched too the afi system with a air box mounted on the fender well. I also had too do some cutting too get it too fit btw. But the price was dirt cheap, no way near the 150, previouys poster paid. I like the sound and the performance. I think it has something to do with the design, not sure. But custom cai's are a vast improvement from stock, keep the faith. make it work.
Old Feb 23, 2011 | 06:12 AM
  #155
miketrock's Avatar
miketrock
Yeah, I didn't mean a built in filter, but hood scoops actually made to function, similar to the hood scoops and air cleaner set-ups of the late 60's and early 70's muscle cars. One of you enterprising guys out there should design and patent one .
Old Feb 23, 2011 | 02:50 PM
  #156
rocket23's Avatar
rocket23
The best I've seen are from suncoast, sadly they are fiberglass deals, which (from what I've read) do not hold up well at high speeds. But they are truly functional. They offer distinct RAM air capability and engine compartment cooling. I type this as the weather is single didgets at night lol. I do not need engine compartment cooling. I have a stick on hood but I will be getting a steel one prolly from the dealer when I get some spare change. Within a year I'm hoping. Till then I'm stuck on stick ons ha ha ha .
Old Feb 28, 2011 | 04:55 PM
  #157
lance0206's Avatar
lance0206
Originally Posted by bwhite757
Sorry I didn't see this until now.
I used 3" diameter PVC, used regular PVC cement to seal the joints. I had planned on buying an Amsoil filter to put on it, but I ended up leaving my K&N 3 1/2" clamp on. Fits perfect, works and sounds great. I'm actually planning on buying a couple better permanent brackets to put on it today, I'll put an updated picture up once I get it done.
The heat issue has been discussed many times. Honestly only time will tell. Schedule 40 is rated for 140 degree liquid to run through it, air temps can probably be a little higher. So far my CAI has only seen a 90 degree day, and the Intake Air Temp reached around 105 (According to my Edge programmer). As long as my intake air temp doesn't get above 150, I'm not going to worry, right now it's solid, still looks good, and doing it's job...
****EDIT****
After talking about my intake for awhile now, and looking at the horrid pictures of it, I've finally finished it up. No more Zip-Ties, and some nice paint:
I like this setup so I went and bought all the piping...Where did you find the bracket metal at? I couldnt find anything that I could make work? Can anyone suggest how to mount this maybe with pics?
Old Mar 2, 2011 | 05:06 PM
  #158
frenchbee2306's Avatar
frenchbee2306
had a KN 57 series..
now got a Vararam....and I love it !!
Old Mar 6, 2011 | 06:06 PM
  #159
rocket23's Avatar
rocket23
nice set up,^^^^.
Old Mar 6, 2011 | 10:52 PM
  #160
SLT8's Avatar
SLT8
Very clean engine bay's in this thread.
