View Poll Results: What CAI do you have or recommend?
K & N
245
35.66%
Air Raid
77
11.21%
AEM
25
3.64%
Mopar
36
5.24%
Volant
59
8.59%
Afe
32
4.66%
True Flow
7
1.02%
S & B
15
2.18%
Ram Hammer
9
1.31%
home made
113
16.45%
ebay or other (specify in a post)
69
10.04%
Voters: 687. You may not vote on this poll
Old Aug 5, 2015, 09:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Cold air intakes
Old Jul 1, 2012 | 11:47 PM
  #281
08HEMI1500's Avatar
08HEMI1500
Actually Hammer did a test of metal versus non metal tubing and found only a couple of degrees difference and nothing that would be noticeable
Old Jul 11, 2012 | 06:27 PM
  #282
Dodge_cowboy2004's Avatar
Dodge_cowboy2004
Made another CAI for my 3.7 to 4.7 swap.
Old Jul 11, 2012 | 11:40 PM
  #283
Ellis42's Avatar
Ellis42
Looks good, I plan on making one similar but haven't got around to it
Old Jul 18, 2012 | 11:33 AM
  #284
DodgeBluto's Avatar
DodgeBluto
Hi Guys, I am new so don't beat on me too bad. I just want to offer advice or suggestions to the DIY crowd.
These DIY intakes and some of the aftermarket are cool looking but really miss the point of a CAI.
90* angles kill flow. You are reducing flow and causing turbulence.
If I recall correctly I think 90* bends reduce airflow by 25-30%. It is a matter of friction for the air, less friction = more flow.
Think of a car driving home full speed with no brakes. When the car comes to a 90* turn, what happens? It smashes into the wall and eventually gets turned in the right direction to get home.
That is what air does, it slams into the 90*, farts around and then heads in the right direction.
There has got to be a better route for the tubing. Maybe one 45* heading straight for the fender or like that Ram guys design with a nice long curve. The less acute the angle the better the flow.
And, I don't understand why you would make a "CAI" with no heat shield. Sucking in heated engine air with a 90* bend is hurting performance over stock.
While I am new to Rams, I am not new to the design of DIY CAIs, I have hashed this out and researched a lot with my Buick as I made my own CAI for the supercharger.
And I am a DIY guy, eventually I will visit my local plumbing store to start my own project too.
Old Jul 18, 2012 | 08:23 PM
  #285
08HEMI1500's Avatar
08HEMI1500
Well when you get around to making your CAI take some pics and post em up! I'm open to making a new one myself
Old Jul 19, 2012 | 08:24 AM
  #286
ewing111's Avatar
ewing111
Good info dodgebluto. I don't think (for most of us anyways) its a lack of understanding about airflow as to why people do the 90 bends and no heat shield. After lots of reading on the forum, there are several things I would summarize. 1: The hemi hat is so restrictive that removing it and putting 90's in DOES increase airflow. There's a couple pics somewhere of the inside of it, it's got bends and u turns all over the place. 2: Proven power gains (or mpg for that matter) are hard to come by, and most guys aren't heading to the track, so the pleasure of making their own intake, the sound of the hemi sucking up air and any incremental gains they get are good enough for most. 3: Sure sucking engine air isn't exactly "cold", but if you are doing your own cai it's a lot easier to not design a heat shield, and just glue some pvc and a filter together.
All that said, if you come up with a good design using 45's or some other less restrictive system of tubing and integrate a good heat shield into it, you will gain a cult following on this site. Most of the guys will agree that would be an improvement over what a lot have done. Be sure to post up a diy if you do, there will be lot's of interest in it (including me)!
Old Jul 19, 2012 | 08:52 AM
  #287
DodgeBluto's Avatar
DodgeBluto
I hear you on the feeling of accomplishment and the smile when you hear that cone sucking air through your own DIY intake. While I am LH (lacking Hemi) I see the hat on my 5.9 is restrictive as well. I will report back when I piece together something
Old Jul 19, 2012 | 12:53 PM
  #288
SLT8's Avatar
SLT8
Can't hear any sucking but it gets the job done.
Old Jul 19, 2012 | 01:07 PM
  #289
Five.SevenRAM's Avatar
Five.SevenRAM
that engine bay looks fantabulous SLT8
Old Jul 23, 2012 | 11:19 PM
  #290
Olerodder's Avatar
Olerodder
Default Cold air intakes
I just installed an Airaid system on my truck. It now has a C.A.R.B. sticker for us guys in California.
The intake works terrific, along with cat back Magnaflow system.
Before I put the air intake on I was getting 20mpg on the highway. I have now made two trips, one 210 mile and one 285 mile...............and I usually drive 65/70mph. Well................on both trips I got 23mpg. I was totally amazed.
I will see what it does pulling my race car.............before I was getting 10mpg hauling the 4000lb trailer/car.
