View Poll Results: What CAI do you have or recommend?
K & N
245
35.66%
Air Raid
77
11.21%
AEM
25
3.64%
Mopar
36
5.24%
Volant
59
8.59%
Afe
32
4.66%
True Flow
7
1.02%
S & B
15
2.18%
Ram Hammer
9
1.31%
home made
113
16.45%
ebay or other (specify in a post)
69
10.04%
Voters: 687. You may not vote on this poll
Old Aug 5, 2015, 09:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Air Intake and Exhaust Guides
Print Wikipost
Cold air intakes
Old Jul 24, 2012 | 08:53 AM
  #291
08HEMI1500's Avatar
08HEMI1500
Is that by the lie-o-meter in the overhead console or hand calculated because when I first installed mine my MPGs jumped up by like 4 until I reset the PCM and then I started getting real numbers
Old Jul 26, 2012 | 01:42 PM
  #292
Olerodder's Avatar
Olerodder
All of my calculations on done by hand and with my internal calculator, although my "lie-O-Matic Meter" is almost always 2 to 3 10ths off my calculations.
Old Jul 27, 2012 | 09:03 AM
  #293
rocket23's Avatar
rocket23
Engine compartment temps are reduced by the ''normal'' flow of air thru the engine bay at any given speed, btw. deleted partial post, pix deleted, my bad.
Old Aug 2, 2012 | 11:37 PM
  #294
Got_Mitch's Avatar
Got_Mitch
Well heres an interesting one.
Installed A Volant Air intake into my 08 1500. And before I put it in. the SC Vivid would tell me my air temp would usually be about 5 - 10 F warming then Ambient. Now with this Volant intake in. I saw a gap as much as 30F while sitting at a light. But at about 40mph Im about 15F warming. So now im thinking did i buy a WAI. But also noticed on the Volant. theres a scoop heading down behind the light, But there is also 2 holes at about 3.5 inch diameter that are on the side away from engine, Im thinking on taping those holes shut.
Ideas?
Old Aug 3, 2012 | 09:01 AM
  #295
rocket23's Avatar
rocket23
Ideas?
install a power wire; here's a link.
https://dodgeforum.com/forum/parts-s...wer-wires.html
Old Aug 3, 2012 | 07:06 PM
  #296
Got_Mitch's Avatar
Got_Mitch
power wire wont cool down the air. like i thought the volant was going to. Its going to lie to the ECU about temperature. Cant see any real gains from that except for making the engine run even leaner???
Old Aug 3, 2012 | 09:57 PM
  #297
08HEMI1500's Avatar
08HEMI1500
Get a heat shield and maybe a jet stream scoop?
Old Aug 4, 2012 | 01:34 AM
  #298
Got_Mitch's Avatar
Got_Mitch
Ive got a scoop coming its on back order right now. just disappointed with the volant at this point. Will need to drive for a few tanks to really see how it does.
Old Aug 4, 2012 | 05:36 PM
  #299
rocket23's Avatar
rocket23
your half right, it will trick the ecm/pcm.......but the air /fuel are both increased at wot, adding hp. not leaning or riching for that matter.It does nothing harmful to the motor.
Old Aug 4, 2012 | 05:37 PM
  #300
rocket23's Avatar
rocket23
scoops are cool!.
