View Poll Results: What oil is in your engine?
Mobil 1
251
32.51%
Royal Purple
123
15.93%
Amsoil
57
7.38%
Valvoline Full Synthetic
86
11.14%
Pennzoil Synthetic
36
4.66%
Castrol Synthetic
65
8.42%
Quaker State 4x4
17
2.20%
Havoline Synthetic
2
0.26%
Other Full Synthetic
29
3.76%
Whatever the Dealership sticks in
28
3.63%
Synthetic Blend (specify in a post)
20
2.59%
Conventional (dino) oil (specify in a post)
58
7.51%
Voters: 772. You may not vote on this poll
Motor Oil
Old Jan 5, 2011 | 09:15 PM
  #101
A14Austin's Avatar
A14Austin
As a Stock Car driver myself we only use mobile 1 in everything.. even the race car. Well now we use Joe Gibbs racing oil but that's not for a hemi lol.. MOBILE 1!
Tony Stewart!
Old Mar 27, 2011 | 01:22 AM
  #102
chefred112's Avatar
chefred112
I've used Amsoil 0w-30 since 06 (about 50k on odo) and today I'm about at 198k...change it every 25-30k miles (Amsoil intervals with oil bypass system)...
Old Mar 27, 2011 | 01:46 PM
  #103
lrnintendo's Avatar
lrnintendo
Mobil 1 with Lucas synthetic additive and Fram filters.
Old Apr 9, 2011 | 10:45 PM
  #104
Lowrider82's Avatar
Lowrider82
just did my first oil change (me personally, shops all the others), and put Royal Purple w/ purolator filter in it. saw a 1mpg increase. i have a 4.7. runs tip top. now on to the plugs this week
Old Apr 20, 2011 | 01:06 AM
  #105
Ripperace's Avatar
Ripperace
I just changed mine and am presently running Mobil1 with a K+N Filter. Will run Amsoil when I become a dealer for it. The reason for this is because of what I saw with my Harley. I run Amsoil exclusively in my Harley now, and it made a HUGE difference in oil temperature in the oil tank. The temp dropped 15 degrees changing from Mobil1 V-Twin oil to Amsoil. So yeah, the Ram will get Amsoil as well. Can't say enough good things about Amsoil.
Ripper
Old May 17, 2011 | 10:18 AM
  #106
pjordan4477's Avatar
pjordan4477
Quaker State 0W-40, in a Durablend if possible.
Old May 20, 2011 | 11:33 PM
  #107
gw8816's Avatar
gw8816
I run Royal Purple across the board Eng, Trans, and Rear end. I use a K&N filter and every 4k or so. Even though we are mostly using Synthetics, it still gets just as dirty as if you were using Dino oil. Why take the chance?
Old Jul 12, 2011 | 05:08 AM
  #108
mike_dmt's Avatar
mike_dmt
Mobil1... I just changed mine after 5k. My '03 has 175k on it. Still fairly clean..Meaning it was not black or much different color from fresh. I believe I use the Fram 6X filter the last couple of changes.
Old Sep 6, 2011 | 07:35 PM
  #109
dj06482's Avatar
dj06482
Just wanted to bump this up for some opinions. My '06 with the HEMI (and MDS) is throwing a P1521 code (incorrect oil viscosity) and I'm actually running Penzoil Platinum 5W-20 (changed about 2.5K ago). Has anyone else had this issue?
If not, what oil and weight are you using in your MDS-equipped HEMI trucks?
Thanks!
Edit: After I replaced my EGR valve (was also getting a fault code on that), the P1521 code went away, as well. Also checked my logs and the oil was changed about 1.5K ago, not 2.5K.
Old Sep 11, 2011 | 09:07 AM
  #110
TheFist's Avatar
TheFist
Haven't seen that at all. I've been using the 5 20 in my mds 1500 and I run it pretty hard and tow about 7000lbs with it at 70-75mph about 5 times a year.
