View Poll Results: What aftermarket Muffler you running?
Dynomax
21
3.88%
Monroe
3
0.55%
Borla
23
4.25%
Flowmaster
178
32.90%
Magnaflow
118
21.81%
Gibson
25
4.62%
Cherry Bomb
76
14.05%
Aero Turbine
30
5.55%
No muffler at all
26
4.81%
Thrush
14
2.59%
Other (please specify in a post)
27
4.99%
Voters: 541. You may not vote on this poll
Muffler
Old Jun 6, 2012 | 12:20 AM
  #161
xDIEGOx's Avatar
xDIEGOx
Looking to replace the exhaust on my 2002 1500 5.9 4x4 quadcab, longbed. Should I go with a bolt on catback exhaust (thinking Gibson), or a custom exhaust with a magnaflow muffler? I live in CA so it must be CARB legal. If I go the custom route, what type of magnaflow muffler would I need? What size piping?
Old Jun 6, 2012 | 02:36 AM
  #162
Ellis42's Avatar
Ellis42
Well if you do custom then you can pick sizing either 2.50 or 3 inch piping, and size of muffler Is totally up to you smaller muffler= louder, so depends on what your really looking for or you could go with the Gibson catback which I have never read a bad review about
Old Oct 1, 2012 | 03:19 PM
  #163
willdikem66's Avatar
willdikem66
Ive had a Flowmaster, Glasspack, other varations of a Flow and nothing was better power wise or sound until i put a Y in place of my muffler
Old Oct 11, 2012 | 06:40 PM
  #164
tronic's Avatar
tronic
i had no cats running into the stock y pipe then going into one super 44 1 in 2 out, into two angle cut tailpipes right out the back, ridiculously loud, sounded good around 1500 to 1900 rpm after that it was like straight pipes, so now i changed it actually yesterday to no cats running straight into the magnaflow tru x crossover, going into 2 seperate borla xr-1 racing multicore mufflers and each muffler goes to its own tailpipe (i guess kind of considered true dual? not sure if it is still with the x pipe) a lot lower volume but the quality of the sound, is amazing plus the x pipe gives me back just enough of the back pressure that i lost before, the 2 borla mufflers gave me my torque back and an amazing sound, getting used to the lower db, but it is probably a normal level, just used to the airplane i was driving for a while
not sure if i need to mufflers or could have gotten a way with one with 2 out into the tailpipe, but i'm super happy going with the extra one, but damn borla is expensive but worth it, 250 a piece, but like i will say a thousand times worth it, although i've only had it one day, so i might have to change my tune in a little, i hope not though
Old Dec 20, 2012 | 12:11 PM
  #165
Willy McNasty's Avatar
Willy McNasty
Originally Posted by OlDirtyJohn
Aero Turbine 3030. Sounds awesome, and gave me some seat of the pants boost at the higher rpms.
http://www.youtube.com/watch?v=OHFSOMEd_N0
Do you get any highway drone in the cab? Did you cut out the resonator as well? Sounds awesome on your video!
Old Dec 21, 2012 | 07:29 AM
  #166
adventurer's Avatar
adventurer
On my 06 i have Magnaflow cat-back single inlet / dual outlet deep throaty sound , and on my 2010 replaced only the stock muffler with pypes violator muffler and kept the resonator (single exhaust pipes) nice sound no drone at all and happy with it at all rpm ranges it made difference
Old Feb 28, 2013 | 12:25 AM
  #167
thehemihead's Avatar
thehemihead
Hey check out my video! Tell me if you like my setup! Magnaflow X-Pipe and 2 Super 10's(equivalent) Better sound quality with headphones or good speakers. Some computers are not able to play the low frequencies well
Old Mar 5, 2013 | 11:56 PM
  #168
eacs10's Avatar
eacs10
I just installed a Flowmaster 40 series with everything else being stock. Any have the same setup? And did u remove the resonator? If so did u like it or hate it?
Thanks
Old May 14, 2013 | 12:15 PM
  #169
dougiedododge's Avatar
dougiedododge
Default muffler
I am running Hooker Aerochambers..First time to use them and I am very pleased.They have a deep throaty rumble to them and Sing so gloriously when in the throttle pretty good.
Old May 14, 2013 | 12:33 PM
  #170
dougiedododge
Default muffler
