Superchips Questions and Updates
Old Aug 31, 2009 | 08:51 PM
  #1121
RubberFrog's Avatar
RubberFrog
No point in rushing things. We all remember what happened when another company rushed the trans options.
Old Aug 31, 2009 | 08:55 PM
  #1122
SilsHemi's Avatar
SilsHemi
Thanks for your patience George.
I've been the guinea pig and we've had a few small bumps, but the testers won't feel those. They are working everything out real well. It should be an awesome final version for sure.
Sil
Old Sep 1, 2009 | 01:25 AM
  #1123
OklaHemi's Avatar
OklaHemi
i am going to have to sell my hyper pac.
Old Sep 1, 2009 | 02:37 AM
  #1124
ArkHemi's Avatar
ArkHemi
Originally Posted by SilsHemi
Ok folks, we're within fractions of having the WOT/PT TM nailed down. Today's latest pre-beta was the best to date. There are just two PT TM RPM ranges and one WOT TM shift that need to be adjusted. You'll be able to ZERO out TM across the board. We're getting closer to a well done product for the 07-08 years. The 04-05 years are going through bench testing.
I can't stress enough how exact they've been during this process. This is going to be a fine tuned release.
Waiting is the most difficult part. I know. I want to keep you all in the loop.
Sil
Uhhh....what about 06?
Old Sep 1, 2009 | 07:12 AM
  #1125
SilsHemi's Avatar
SilsHemi
06 will be supported. Unless SC changes the order, right now the order they're working in is: 07-08, 04-05, 06.
Sil
Old Sep 1, 2009 | 04:56 PM
  #1126
ThunderedRod's Avatar
ThunderedRod
This is a bit off topic but it is the place for superchip questions. I called superchip today to ask about any problems i might have with my TTi long tube headers and y-pipes that i am installing. They said the long tubes will create a lean condition. Will i be okay? Should i not run the tune? Should I install a air-fuel gauge and keep an eye on it? I really want to be able to use the tuner with the headers.
Old Sep 1, 2009 | 06:18 PM
  #1127
joe44473's Avatar
joe44473
what bout 03 ram will they be coming up soon or gettin left behind?
Old Sep 1, 2009 | 08:28 PM
  #1128
Off_Road_Teacher's Avatar
Off_Road_Teacher
From what I have read (I don't have an A/F gauge so I don't know for sure) the SC 91 tune already leans out the mix a little. So adding some LT's will probably lean it out even more. How lean will it get, I don't know. You will have to install an A/F gauge to find out.
Old Sep 1, 2009 | 09:23 PM
  #1129
ThunderedRod
I mean I am planninng on installing a cut out too. i just dont want to burn up any valves. I just read last night that 14.7:1 is the factory mixture. Shouldn't the PMC strive to keep that ratio even though it is a superchip tune? Or has my trucks computer reached its limits?
Old Sep 1, 2009 | 10:33 PM
  #1130
Got_Hemi44's Avatar
Got_Hemi44
03 will not be supported. Only 04-08
