Superchips Questions and Updates
Old Aug 2, 2010 | 10:37 PM
  #2511
xtremekramer's Avatar
xtremekramer
So i tried to do some data logging over the weekend. How do you replay it? I did the advanced real time log and watched it start and stop recording (hitting the ok button like the screen states) but see no way to play it back. Also, is there any way to get more then 4 items at a time?
The Diablo was able to run every one you selected at the same time and had a playback button. Was great to data log my way to the park. Stop and check things out and make small changes and log my way back home checking out the changes when i made it home.
Old Aug 3, 2010 | 01:34 PM
  #2512
Ric@rdo's Avatar
Ric@rdo
Last 2 days I've used the 87 tune. Today morning I loaded the 91 perf tune again. Uau!! What a difference...
Old Aug 4, 2010 | 10:03 AM
  #2513
runvs's Avatar
runvs
can you update a superchip micromax tuner for a 03 hemi ?
Old Aug 4, 2010 | 10:55 AM
  #2514
Scott@Superchips's Avatar
Scott@Superchips
Former Vendor
The Max Micro tuner has been discontinued from our production line which also limits support.
That being said, it doesn't hurt to check with customer service to see if there are any final updates available for that unit that might benefit you.
You could also consider taking advantage of our trade up program we have going on that gives you cash for your Max Micro trade in towards a new Flashpaq programmer.
Customer service can be reached at 888-227-2447.
Scott
Old Aug 5, 2010 | 06:01 PM
  #2515
tattoo-dragon's Avatar
tattoo-dragon
Hello,
New here and have a question that may have been asked on here at some point.
Living in Atlanta, we are required to have annual emmisions checks prior to renewing tags. I had my truck programmed for performance and forgot to return it to stock BEFORE having the emmisions check completed. As a result, my engine ecm was reflashed back to stock but not the transmission. Recently I began pulling a trailer frequently and attempted to re-program my truck to Towing. It displayed Unmatched VIN. A call to Superchips and within a few days it was unlocked.
Here is the issue now. It displays the error code E-43. A second call to Superchips revealed the fact that the two ecms currently have two different programs and therefore, the programmer is unable to tune. Superchips advised me to have the dealer re-flash both ecms to stock so the programmer will recognize both programs.
The question: Does anyone have an idea as to what the dealer may charge for this and if there are any other options to getting both reflashed?
Thanks for listening,
TG
Old Aug 5, 2010 | 06:14 PM
  #2516
rengnath's Avatar
rengnath
Originally Posted by tattoo-dragon
Hello,
TG
For the dealer to reflash my PCM, they quoted me $90.
Old Aug 6, 2010 | 10:11 AM
  #2517
RedTruck-VA's Avatar
RedTruck-VA
I have just had my dealer reflash my PCM on my 03 and they charge $30 per item. Meaning $30 for the PCM and another $30 for ABS reset.
Old Aug 6, 2010 | 10:19 AM
  #2518
RedTruck-VA
Originally Posted by Raden
Didn't know if it was ok to post or not... 4wheelonline.com
Question, I ordered mine 8/1/10 and still haven't recieved anything. Their customer support is lousy. I am starting to not like it..
Update: Emailed this morning for a tracking number. Recieved the tracking number about thirty minutes before the tuner was deliveried. I have recieved the tracking number three more times since I recieved the tuner. All this customer support would have been better appreciated two or three days ago.
Old Aug 6, 2010 | 12:01 PM
  #2519
snowhill's Avatar
snowhill
I´m little confused about the part throttle torque managment. It gives you 4 RPM levels to change TM in part throttle. I have RAM 1500, 2007 model. I dont want to play with it until i know more about it. I cant find any information about those settings. Can anyone tell me his settings so i can get any idea?
Old Aug 6, 2010 | 12:07 PM
  #2520
Raden's Avatar
Raden
Still haven't gotten mine either. Makes me wish I had ordered it from somewhere I've ordered from before, saving a few bucks isn't worth the worry or hassle.
Ok just called and they said it had been out of stock at the warehouse and shipped today, don't know if I believe them or not.
