Superchips Questions and Updates
Old Sep 15, 2010 | 07:36 PM
  #2621
RedTruck-VA's Avatar
RedTruck-VA
Originally Posted by HemiDak-Quad
Q#1- I put a 2004 Motor and trans in my 2001 Dakota and used a 2003 wiring harness I have streight pipes"NO CATS"with stock exhaust manifolds...Can I still plug in a 5.7 power commander under the dash of the Dakota?
Q#2- My truck stops going any faster at around-110 MPH.The engine shuts down. Can I change that with a chip or power commander?
Q#3- Which power commander would be the best to buy.There are many out there and they all say they do the same thing.But the price differance between them are in the hundreds.Is it one of those"You get what you pay for" things ?
I plan on going with a small shot of Nitrous "Every once in a while"...what will this effect..
Thanks....."George".AKA.HemiDak-Quad...
Good job on completing the swap, too bad about using the 03 PCM. It really limits the support that's available. As for speed limiter, SC can adjust that up to 140 mph. A older version SC3815 will do you fine as there is no trans control for the 03. Good luck..
Old Sep 24, 2010 | 04:47 PM
  #2622
ram man17's Avatar
ram man17
I posted about this problem once but havent tried it out again til now and its still there. WHenever I try and change the tranny control from stock or superchips to user the unit restarts. So before it was stuck on stock but now its on superchips and cant get it to user without it restarting. And yes, I bought the update when it was properly released for 4.7s
Old Sep 28, 2010 | 10:24 AM
  #2623
MDSBigPaPa's Avatar
MDSBigPaPa
Send Scott@Superchips a PM and let him know. He'll be glad to help you out.
Old Sep 28, 2010 | 11:05 AM
  #2624
Scott@Superchips's Avatar
Scott@Superchips
Former Vendor
Let's get you in touch with a customer service agent about this issue. it might be something that can be addressed through t internet update.
Customer service can be reached at 888-227-2447.
Scott
Old Sep 28, 2010 | 09:57 PM
  #2625
scwpd's Avatar
scwpd
so i got me a super chips tuner today. first thing i did like it said is update it. the first update went good but now i have a problem with the update program crashing. anyone else having this problem?
Old Sep 29, 2010 | 09:46 PM
  #2626
Invigor's Avatar
Invigor
Does anyone know if Superchips is going to add an option for the laterer years to make it so you can run your foglights with your high beams?
Old Sep 30, 2010 | 03:19 PM
  #2627
Scott@Superchips
Former Vendor
That is something we have discussed in a few meetings. I will update you if we get the go ahead to explore some of these features in more depth.
Scott
Old Sep 30, 2010 | 08:36 PM
  #2628
ram man17's Avatar
ram man17
looks like a new update fixed my problems! i have had it set on superchips since the day it came out and couldnt believe how great it was compared to stock! now cant wait to finally use custom shift points
Old Oct 2, 2010 | 07:19 PM
  #2629
vincent714028's Avatar
vincent714028
Does the 3865 flashpaq actually adjust firmness in its transmission programming for an 04 ram hemi? The user setting in advanced options only gives me adjustment at WOT but the superchips trans tune setting may adjust for firmness i don't know.
Old Oct 7, 2010 | 02:54 PM
  #2630
bighornram08's Avatar
bighornram08
Does anyone know if the superchip 3865 will work for the 2008 4.7L flexfuel? I know it says it works for 2008 4.7L, but its the flexfuel part im not sure about. Trying to be sure before purchase. Thanks
