Superchips Questions and Updates
Old Sep 6, 2011 | 07:53 PM
  #3101
shrimp_2's Avatar
shrimp_2
i just got a 3865 and was wondering how long does it take to put on the software? i downloaded the software and plugged it in and two errors popped up and i clicked okay and now it says analyzing hardware. so does that mean its updating or what???
Old Sep 6, 2011 | 08:00 PM
  #3102
MDSBigPaPa's Avatar
MDSBigPaPa
What, exactly, were the errors? You could try to unplug the tuner's USB cable and plug it in again.
Old Sep 6, 2011 | 08:19 PM
  #3103
KrzyKanuck's Avatar
KrzyKanuck
may be a stupid question, I havn't updated my tuner in a while, just did it today. But I was just curious, have the files changed that dramatically performance wise or are the updates more for the customization options. I have been runnig the 91 octane, but do I re-tune my truck after this update?
also, when I do an update, I usually set truck back to stock, start to ensure all went good, turn off, pull battery cable for a few mins to reset computer, restart truck, turn off, reprogram, restart, pull cable and restart a final time for a final reboot.... am I going overboard?
edit- '03 dodge, kn cai, mbrp duals
Old Sep 6, 2011 | 08:35 PM
  #3104
shrimp_2's Avatar
shrimp_2
I'm not sure but i uninstalled software and restarted computer then downloaded it again and it worked.
Old Sep 6, 2011 | 10:13 PM
  #3105
shrimp_2's Avatar
shrimp_2
alright so i was playing with my 3865 for an 06 hemi qc and could not find a mds disable option. ): does it not have one? also how do i adjust shifting points? i found where it says them but it said SC which means what? one more question, can i use 89 octane with the 87 tune?my truck is stock accept 305/40/22's.please help
Old Sep 7, 2011 | 11:47 AM
  #3106
heatonsV10's Avatar
heatonsV10
I know this is the 3rd generation ram but I was wondering if anyone has seen tuner chips of the 2nd gen v10's
Old Sep 7, 2011 | 09:07 PM
  #3107
MDSBigPaPa's Avatar
MDSBigPaPa
Just a little over the top. No need to return to stock prior to re-tuning. I usually update my tuner about once a month but, I don't always re-tune my truck. If the firmware is updated then I'll re-tune because that usually means some functionality has been added/changed. If there is a change to your truck's calibration, SC usually sends an e-mail to let you know.
To reset the PCM, pull the positive (+) cable and ground it to a good ground for 30 second. I might do this every-other month or so but, if I make a change to the truck - new exhaust, tune up... I reset the PCM so it relearns the new mods.
Old Sep 12, 2011 | 06:29 PM
  #3108
shrimp_2's Avatar
shrimp_2
sorry but another question.. how much hp does the 87 and 91 tune add?
Old Sep 13, 2011 | 08:31 PM
  #3109
1 bad bolt's Avatar
1 bad bolt
im looking into buy a used tuner and have a question will the tunes be different for a hemi with mds vs a non mds truck? on there website in there search bar they give them option for both trucks with hemis. just curious buying a tuner from a 06 ram hemi to a 08 with mds.
Old Sep 13, 2011 | 10:01 PM
  #3110
shrimp_2's Avatar
shrimp_2
2006 rams also have mds
