Superchips Questions and Updates
Old Jun 15, 2009 | 10:47 AM
  #661
Off_Road_Teacher's Avatar
Off_Road_Teacher
Originally Posted by SilsHemi
Folks,
The Flashpaq forum is working again.
Sil
Sil, are you sure it is working? When I go on and click on a topic I get a screen that says debug mode.
Old Jun 15, 2009 | 11:01 AM
  #662
truckin151's Avatar
truckin151
Originally Posted by dyehard
I think thats were my problem is because its minimum rev limit is 0100 and its max is 0600. I was playing with it and i can adjust the shift points if i set the rev limit below 0200. I thought that those numbers were odd.
Something doesn't sound right with those numbers at all they just re adjusted the max rev limit to 6500 not to long ago. Its been a few years since I had mine set to the 87 econo tune but Im fairly possitive that you could adjust the rev limiter and WOT shift points the same as in the 91 performance tune.
Anyway, when I had mine tuned with the SC3815 this is how I had mine set:
RevLimiter 6300
WOT1-2 6150
WOT2-3 6050
It pulled really nice, specially in the 2000+rpm range when passing on the freeway.
Old Jun 15, 2009 | 01:09 PM
  #663
dyehard's Avatar
dyehard
After some testing yesterday I found that my tranny still shifts stock after I adjusted them with my sc. I read that some others with 4.7s were having the same issue. if anyone could let me know what I need to do the fix that it would be great
Old Jun 17, 2009 | 03:55 PM
  #664
RedTruck-VA's Avatar
RedTruck-VA
Default Gear ratio question
I'm using a SC3865 and see where to select tire size, but how do I select a different gear ratio?
Any help is appreciated.
Old Jun 18, 2009 | 09:22 AM
  #665
gish71's Avatar
gish71
Post up your problem on the below SC forum .
http://www.flashpaq.com/forum/viewtopic.php?t=5318
I had the same issue but with their help I'm now working.
Good luck !
Old Jun 19, 2009 | 11:13 AM
  #666
SilverBullet08's Avatar
SilverBullet08
so any timeline when these new features that will blow others out of the water are going to come out??
Old Jun 19, 2009 | 11:21 AM
  #667
SilsHemi's Avatar
SilsHemi
No definitive timeline yet, but they are being worked. You'll be pleased.
Sil
Old Jun 23, 2009 | 01:01 PM
  #668
RedTruck-VA
Default FlashPaq Forum is Down.
As mentioned before, the FlashPaq Forum remains down. I sent an email to your Tech folks on the SC site and have recieved no reply. I have been checking the forum everyday and it remains down. I am assuming there is either a lack of interest or technical ability to get your site back up and running again. I am a fairly new owner of a SC3865 and like the improvements it as made to my truck. However, I have to ask, why isn't your forum being repaired? If you check the dates of the last post on the forum. Thats how long it's been down. Please let us know what is happening with the product we have bought into. Any input is appreciated.
Old Jun 23, 2009 | 03:35 PM
  #669
Scott@Superchips's Avatar
Scott@Superchips
Former Vendor
"Update"
The south Florida company we have contracted to host the Flashpaq.com forum is haveing several hardware and software issues that is not only causing you grief but us as well. Please be patient with us on this as we are working on a resolution and hope to have the issue resolved shortly.
Scott
Old Jun 23, 2009 | 03:38 PM
  #670
SilsHemi's Avatar
SilsHemi
Originally Posted by Scott@Superchips
"Update"
Scott
Thank you Scott.
Sil
