Diablo Information and Reviews
Old Oct 19, 2010 | 08:04 PM
  #781
mpk1980's Avatar
mpk1980
Originally Posted by truckin151
When you did the tire adjustment did the truck "ding" at you after you set it and hit ok? The tire size should have been under the engine file too not the transmission file, did you make any adjustments to the trans?
yeah...got it all figured out....it dinged and said it sucessfully did it....and i confirmed it with DS....but there is no definite way to really see what the setting are.
only 2 things i screwed with in the menu was mds (which i dont think i have anyways but set it to off) and the tire size...im too chicken at the moment to screw with anything else.
Old Oct 20, 2010 | 10:37 PM
  #782
truckin151's Avatar
truckin151
Aw you're not tapping into what this thing can really do with an 05' then... I have a list of shift points on the first few pages somewhere of a good starting point for the partial up/down and WOT setting, you need to play with the throttle sensativity and as long as you stay away from the fuel and spark adjustments until you get a wideband and do some logs, you wont hurt anything.
Originally Posted by glass3222
I have never had this problem....did you get it figured out?
Yep, turns out it was using the wrong baud rate for the downloads, changed it to the correct one and it worked like a charm. Now I am working on getting a custom tune for it... and later the 268 goes in.
Old Oct 21, 2010 | 10:15 AM
  #783
mpk1980's Avatar
mpk1980
ok...just did i guess a log for knock...watched it live from the dsp.....it was 0 for both lt and st i believe .....total max stayed between 12 and 15 usually and then 0 for the last one....so im guessing that was a successful, no knock run of the 91oct tune......going to try the 93 tune now, and if that is successful, will start using the shift points you posted.
Old Oct 21, 2010 | 10:53 AM
  #784
mpk1980's Avatar
mpk1980
Ok...93tune done and same results as 91.....no knock...wooo....now....those shift points....are they better than the perf trans tune ones without being messed with? also, any idea of where i should start with throttle response if i were to mess with it?
Old Oct 24, 2010 | 03:44 PM
  #785
truckin151's Avatar
truckin151
PM Sent
Old Oct 24, 2010 | 04:59 PM
  #786
traker1001's Avatar
traker1001
Truckin I would like to know what your response to his question was. Im getting ready to start playing with my DSP again soon also.
Old Oct 24, 2010 | 09:19 PM
  #787
truckin151's Avatar
truckin151
When I get back to my computer I will post up what I told him in the pm I sent earlier
Old Oct 24, 2010 | 09:57 PM
  #788
truckin151's Avatar
truckin151
Alright this is what I told him to answer some of the questions he had,
Right now my Shift Schedule is this:
Downshifts (+/-)
2-1 at 5% 1325
2-1 at 80% 3000
3-2 at 45% 4100
3-2 at 55% 4750
3-2 at 75% 5250
Upshifts (+/-)
1-2 20% 1927
1-2 30% 2891
1-2 60% 5151
1-2 80% 5450
2-3 15% 1800
2-3 25% 2200
2-3 60% 5390
2-3 80% 5550
WOT Shifts
1-2 6100
2-3 6000
Rev Limiter
6300
Those are a combo for both comfort and performance, they make the truck just feel right, it also runs a bit quicker than what the canned tune has with those points.
You still get the kick down, just not as much since that has more to do with the throttle sensativity and the fly-by-wire throttle so it takes a second for the computer to read that the peddal has been mashed to the floor. Mine has gotten much better though since I added a ported throttle body.
For the throttle sensativity, start with plus 10 and add from there til it feels right. Mine, with the ported TB, really liked +10.5 but that was because it was so much more sensative with the ported TB. With the stock TB I know a few guys have just cranked it all the way to +20 and really like that setting, so do what you want until it feels right.
Right now though, my engine has a custom tune in it (just the PCM) so I really cant tell you what some of the engine parameters are set to but I can say it is running soooooooooo much better and feels like it has quite a bit more power than it ever did running on diablos canned performance tune.
I have also been looking into a transmission custom tune as well but I only know of one guy that is attempting that and he has not been doing it very long so I am going to wait to see how his tunes go before I see about getting one for the TCM.
Also I would suggest going to the 9r09 CROM if you have not updated to it yet. Before the custom tune I swapped to it and it felt like the tune was a little more aggressive than the previous verssions. But again now that I have the custom tune, it completely blows those tunes out of the water. If you really want the most out of your truck, a good custom tune is definately a must.
If you need any other information feel free to ask.
Old Oct 30, 2010 | 09:33 PM
  #789
bigtigga84's Avatar
bigtigga84
finally got my diablo............ and the fun begins. anybody have any suggestions for an 06 up and down shifts?
Old Nov 9, 2010 | 09:48 PM
  #790
silvernos's Avatar
silvernos
So for the 03 what is the best programmer... and if you guys haven't heard of it check this web page out for mods on the Dodge's ie the cam mods.... wicked...
