Diablo Information and Reviews
A custom tune specifically for your truck is better than the canned tunes that come on the programmer any day of the week. Normally you would not need one but I would go as far as if you have done all the bolt ons a custom tune will do you good. I had one for my truck to get it to run a little better before my cam was installed and I have to say that my truck ran much nicer than it did with the canned tune. But now with my cam I have to have a custom tune
Not what but who. HemiFever is a guy who does custom tuning. His name is Sean. A lot of guys like and use him but there are others also. If you are thinking of custom tuning make sure you get a tuner that can datalog like the Diablo and make sure you get a wideband AFR setup like the Innovate LC1
Not what but who. HemiFever is a guy who does custom tuning. His name is Sean. A lot of guys like and use him but there are others also. If you are thinking of custom tuning make sure you get a tuner that can datalog like the Diablo and make sure you get a wideband AFR setup like the Innovate LC1[/quote]
As I had mentioned, i`m a noob. What is or who, AFR and the Innovate LC1? And i`m leaning towards the Superchips 3865
AFR- Air Fuel Ratio.
Innovate LC1:
http://www.innovatemotorsports.com/products/lc1.php
Superchips, does not offer custom tuning at this time. That's usually SCT or Diablo, and some other high end tuners. You'll be fine with a canned tune, probably 90% or more of the guys using tuners run the supplied tunes.
Keep asking, keep learning, I mean what the heck, it's free.
Innovate LC1:
http://www.hemifevertuning.com/
AFR - Air Fuel Ratio
Did you say your truck was an 03'? If it is an 03' Hemi, I wouldnt waste the money on the 3865, it will only do as much as the 3815 will and you should be able to find them cheap as dirt now days.
The DSP wont do you any good on the 03's either as the items you can adjust are few and far between.
