Data Loggers
Old May 2, 2010 | 10:48 PM
  #391
AZZO540's Avatar
AZZO540
Originally Posted by 03MopaRamman
OK, No probs. Your Diff gearing should be listed on the sticker in your glove box lid, if you have one (I mean sticker), I'm guessin you got 3.92 being a Laramie? Cause you are pretty quick for almost stock, you got a strong mill in that sled. Alternatively you can crawl underneath and read the Tag thats attached to one of your Diff Cvr bolts usually RH side near top.
My tuner says it is a 3.55 rearend
3.92 is an option i bought mine used or i would have prefered it. wanna 4.10 next but will wait on other mods 1st
Old May 3, 2010 | 08:54 AM
  #392
RedTruck-VA's Avatar
RedTruck-VA
AZZO, Where does your tuner tell you your gear ratio?
Old May 3, 2010 | 09:15 AM
  #393
AZZO540's Avatar
AZZO540
where you can change the ratio
it starts with what truck say it has
i THINK
Old May 3, 2010 | 09:43 AM
  #394
truckin151's Avatar
truckin151
Dont go off the tuner, visually check it
Old May 3, 2010 | 11:21 AM
  #395
Maori's Avatar
Maori
Wow the SC can indicate your gear ratio now?
Never knew that but x2 on what truckin said about visually checking it.
Old May 3, 2010 | 04:57 PM
  #396
03MopaRamman's Avatar
03MopaRamman
i THINK
I only asked about the gear ratio cause I was confused about the timings vs a 6700 lb QC with SC only since I am in my mind, trying to find out what a stock QC was and no such luck so far since I have done a few mods (including SC) and surely should be quicker than what I am reading (7.91) regardless of elevation and 3.55 gear ratio.
(The Gear ratio Adj. is not avail for the 03 forgottens).
So AZZ0540 Dude you should enter the verified gear ratio, and if applicable measure your tires with a tape and enter the diameter in inches, as leaving it on minimum (31 " or whatever?) lmight throw off the Data-Log.
Old May 3, 2010 | 07:34 PM
  #397
RedTruck-VA
I adjusted my speedometer by first measuring my tire hieght and then making some passes on one of those radar signs in a nearby town. Gear ratio is read off of the tone ring located in the differential and is the VSS/RWAL sensor. Tire size is critcal to the tuner reading properly. Good luck...
Old May 3, 2010 | 07:58 PM
  #398
Off_Road_Teacher's Avatar
Off_Road_Teacher
Stock Hemi larime
Wgt 6700LBS Fin heavy
Do you have anything extra on your truck? Winch, big rims or tires, grill guard, etc? That weight seems awfully heavy for a 1500.
Old May 3, 2010 | 09:46 PM
  #399
AZZO540's Avatar
AZZO540
6700 is the wgt paper work say
i boughtg it used i don't think there ne thing specail on it.
Just intalled K&N intake got 9.31 0-70 w/o Trac ctrl w/ F ton of tire spin.
need to do better run but cop pulled just as i started to do 2nd run
.1 sec off w/o tire spin should have been good run
Love the tone it adds to truck.
Old May 3, 2010 | 09:48 PM
  #400
AZZO540's Avatar
AZZO540
How
I sure don't know the diff, owned truck 2 months
