Data Loggers
#531
I was getting a bit excited at first reading about wideband and then I woke up in the realm of the forgottens. You can't rev past stock now Greg so I see a 1500 to 5800 Cam and custom Tune in your future as the best solution and that will get you into the 5's where you belong (its only money).
#532
#533
I played with the DSP today. This is rather disappointing. The only adjustments for the 03 model are Tire size, WOT Timing and WOT Fuel.
Not knowing where to start, I adjusted them to the following.
The settings are for WOT only:
1 -3.8 rpm, spark 4+ degree, Fuel +8%
4 -4.8 rpm, spark 3+ degree, Fuel +8%
5 -7k rpm, spark 2+ degree, Fuel +8%
I made a single run and it felt ok and ran a 6.30 (0-60 mph) which is consistant with the 93 Tune I first installed. Yes, I use 93 octane.
Pls, give me some input on what you guys are setting these parameters at. Any suggestions would be appreciated.
#535
Do you have a wideband yet???? If you dont... DO NOT MESS with any of those settings you're going to be running pig rich like that too. I have mine set +6.5%, +1% +1% fuel and that with the LT's which lean it out. Also your 180* Tstat will richen it up even more.
Plug a laptop into it and do some logging cause I have a feeling that if you keep it like that you're going to hurt something
#536
There are other factors that go into that, the quadcabs have better traction that us RCSB and the DA/Elevation of the runs make a huge difference in times too
#537
im in tx doing my times in 100+ degree weather...
#538
I would like to see a breakdown of each of your runs, like 0-10, 0-20 and so on up to 60. Something seems off bc he should be faster than you bullet, at least based on both of your mod lists and truck weight.
#540
Less weight = lots of wheel spin, it doesn't really matter that we have about 500lbs less weight than you guys do, its a fact, QC have better traction because of the extra weight and longer wheel base (also why they ride smoother too).
But elevation will kill times though.
