Last edit by: IB Advertising
Browse all: Tire Repair and Maintenance
- Dodge Ram: Tire Modifications and Size Calculator
Overview of popular modifications to customize your Ram
WHEEL & TIRE FITMENT on DODGE RAM
#92
I have 02 Ram 1500 2wd, with a 3 inch Rough Country Lift. Can i fit LT285/75R17 E121/118Q Nitto Trail Grapplers on stock rims. Nitto website says tires are 34.09 x 11.57. I am Ok with some rubbing on tight turns.
#93
Gig'Em.
#94
Thanks and Gig'em
#95
I have a 2003 Dodge ram 1500 4 door 4wd truck and eventually i wanna level it. So i want 18in rims with 33in Nitto terra grapplers what size tires should i get for that to make it look good as far as width and height?
#96
Hi guys im a noob here and im sorry for this stupid question but i dont have any idea on specs or anything about rims and tires and i just want some of your knowledgable answers, Ok i got the stock 20 inch rims and tires on my 2008 dodge ram quad cab no lift and recently purchased some guys 20 inch moto metal rims on craigslist which is 20x10 and i would like to know what size tire you guys recommend that wont have any issue rubbing and the cheapest one too since i wont use it that much offroading thanx so much!
#97
you can fit 36 1350 on a 2008 4x4 with just a leveling kit and the rims are 17x9 with +10 back spacing and they do not rub on the ball joints or anything at all.
#98
A lot of good info noobie here looking to put some bigger tires on my 07 ram 2wd looking for recomendations. i think im going to order the 3 inch body kit w leveling kit giving me 5 inch lift. i have 20 inch stock rims which im going to stick with for now. i have narrowed my tire brand down to the cooper zeon or the nitto at tires. what size tires should i go with. i was looking at 305/55 r 20 but then realized they were same hieght as stock. should i go with 325? i dont want the tire to look to big in fender well. if anyone has some pic with this set up it would me out. thanks for the help
#99
First here's my story.
"When I put my 07 1500 in 4 wheel lock when I accelerate there's a rather nasty vibration. I have the lifetime drive train warranty on it and the dealer has replaced the right front CV joint and axle only because it was leaking by the seal where the axle goes in. After they replaced it, it still vibrated, so today they put in another shaft and it still vibrates. Needless to say I'm a bit pissed at this dealer right now. Anyone have any ideas as to why it vibrates in 4X4 only? I have a 2" leveling kit for like 3-4 years now."
Now my question. My dealer is willing to remove my 2" leveling kit at their expanse to see if the vibration is from it. Now I have BFG AT KO 285/65/20 with stock wheels on my truck. There 11.5 wide and per BFG 34.7 tall ( I call BS on the 34.7). So if I have my dealer pull the leveling kit will these tires clear everything? From what I've read here yes.
