View Poll Results: Have you had good results by Grounding the TB ?
Yes
39
81.25%
No
9
18.75%
Voters: 48. You may not vote on this poll
grounding the TB ???
Old Jan 26, 2012 | 11:26 PM
  #71
truckin151's Avatar
truckin151
Yeah, was hoping though after hearing all the plus' about it smoothening out the idle that it have some effect though. Have to see how she runs over the weekend.
Old Jan 27, 2012 | 05:48 PM
  #72
hyperjay's Avatar
hyperjay
Well........figured I'd try this too. Used 8AWG and went to the driverside ground as it is closer to the neg battery terminal. If it did improve throttle response it's minimal. Still idles steady at 600, and shifts about the same.
Old Jan 27, 2012 | 06:18 PM
  #73
08HEMI1500's Avatar
08HEMI1500
Can you buy the wire with the ends on them or do you have to get it all separately?
Old Jan 27, 2012 | 06:28 PM
  #74
hyperjay's Avatar
hyperjay
I didn't have anything laying around for this mod, so everything was bought separately. Bought the 8 gauge amp wire from Walmart. Had to go to Menards to get the ring terminals, heat shrink, and a cheap pliers big enough to crimp the terminals.
Old Jan 27, 2012 | 07:01 PM
  #75
MoparPaul's Avatar
MoparPaul
Walmart in the battery cable section there is an Everstart 6awg lawn tractor 49"black coated copper cable ready to go for $6.
No fuss no muss!
Old Jan 27, 2012 | 08:49 PM
  #76
HammerZ71's Avatar
HammerZ71
Yeah, I just happened to have a 36" 4 AWG I use for connecting batteries to run a 24v trolling motor, pre-terminated. You can get a pre-terminated battery cable at any auto parts store for $4-6, do the Wally World thing or just make one up.
I had all kinds of wire for lights around, but nothing thicker than 16 gauge. 16 AWG would do it, but I was more afraid of working under the hood and catching it on something and snapping the wire or pulling out an end. If I had say 10 gauge I would have just made one up...
Old Jan 27, 2012 | 09:43 PM
  #77
08HEMI1500's Avatar
08HEMI1500
And is there a certain size ring terminal or are they all the same? Or do I just have to eyeball it
Old Jan 27, 2012 | 10:30 PM
  #78
hyperjay's Avatar
hyperjay
The ring terminal size is going to depend on what size wire you are using, and the diameter of the bolt you are going to attach it to. I used 6AWG 1/4" Stud, tin plated copper terminals on my 8AWG wire. I still had to drill out the hole bigger for the ground bolt on the body to fit through.
Old Jan 28, 2012 | 02:19 PM
  #79
08HEMI1500's Avatar
08HEMI1500
Ok just did this using a 40" 4AWG wire from Advanced and I got to test it out when I went back there to go get a bigger air filter since I decided to replace my cheap Spectre one while i was under the hood and it could be a placebo effect but I did notice slightly better throttle response especially going into WOT. There was a lot less lag
Old Jan 28, 2012 | 04:26 PM
  #80
adventurer's Avatar
adventurer
No its not a placebo effect , reset the PCM and try your truck
