dodge ram stock ride height
Old Feb 25, 2010 | 11:41 AM
dodgegirl05's Avatar
dodgegirl05
Default dodge ram stock ride height
hi all, ive been trying to find the stock ride height of my truck?
i have a 2005 dodge ram 2500 heavy duty 4x4.
thanks all!
Old Feb 25, 2010 | 11:51 AM
Blackhawkdoc's Avatar
Blackhawkdoc
Length: 229.7 in. Width: 79.9 in. Height: 73.8 in. Wheel Base: 140.5 in. Ground Clearance: 8 in. Curb Weight: 5452 lbs. Gross Weight: 8650 lbs. Length: 229.7 in. Width: 79.9 in. Height: 73.8 in. Wheel Base: 140.5 in. Ground Clearance: 8 in. Curb Weight: 5452 lbs. Gross Weight: 8650 lbs. Length: 229.7 in. Width: 79.9 in. Height: 73.8 in. Wheel Base: 140.5 in. Ground Clearance: 8 in. Curb Weight: 5452 lbs. Gross Weight: 8650 lbs. 73.8inches.... http://www.edmunds.com/used/2005/dod...488/specs.html
Old Feb 25, 2010 | 11:52 AM
Blackhawkdoc
Sry...Didnt realize i hit Ctrl-V so many times..haha hope this helps!
Old Feb 25, 2010 | 12:54 PM
dodgegirl05
ok thanks! i was only asking cause the place i usually get my inspection sticker told me im too high. all i have is a 2" leveling kit on 35's. which i dont think its that high!
Old Feb 25, 2010 | 01:06 PM
SlvrRAM05's Avatar
SlvrRAM05
Your bumper height may be too high with the lift and 35s...some states are a-holes on bumper height....What state do you need to pass inspection in?
Old Feb 25, 2010 | 01:10 PM
dodgegirl05
Massachusetts lol the worst state out there!
Old Feb 25, 2010 | 01:14 PM
OlDirtyJohn's Avatar
OlDirtyJohn
you have a 5.9l hemi? sweet
Old Feb 25, 2010 | 01:17 PM
SlvrRAM05's Avatar
SlvrRAM05
Here's the formula for figuring lift allowable...
Get out your calculator: The maximum allowable mechanical lift (as well as what's acceptable in terms of bigger rubber) can be determined by this formula:
Maximum Lift = Wheelbase x Wheel Track
2200
For example, if you did that formula and came up with 2 inches, then a 2-inch lift and a 2-inch increase in tire size is allowable, equaling a total lift of 4 inches over stock.
Edit : This was apparently in the year 2000...Searching for updated info
Double Edit : This only applies to 4wd vehicles...If you're truck is 2wd it's 2" over stock height...period
Rep586's Avatar
Rep586
im glad they dont have those inspections in Michigan lol
Old Feb 25, 2010 | 01:21 PM
4.7Ram5.7Rango's Avatar
4.7Ram5.7Rango
Lol Dirty....
Helluva ride you got there Ms. Hows bout some pics of that rig? And maybe the driver too
