HID's Installed (Heads/Fogs) Also **DYNO BONUS**
Old May 12, 2010 | 04:38 PM
Trupiano's Avatar
Trupiano
Yeah sounds about right john. I have a good idea then. Ill get some skinny rubber peices of some kind and put a few strips between the ballasts and the frame. Maybe that will help?
Old May 12, 2010 | 04:46 PM
Trupiano's Avatar
Trupiano
Hey, something else I just noticed. Why are my high beams the stock color? I thought the High and low beams would be 6000K? Even if the high beams aren't HID's, I'd still like them to be the same color.
Old May 12, 2010 | 05:06 PM
Animal Mother's Avatar
Animal Mother
I have a whole other set of ballasts and bulbs for my highs
Old May 12, 2010 | 05:08 PM
Trupiano's Avatar
Trupiano
Ill have to think about whether I need them or not. I mean, honestly I dont think ill ever use them, the HIDs for my lows and fogs provide more light than my highs ever would. Thanks, least I know I can get them now. That a 2/4 drop or 3/5? looks great!
Old May 12, 2010 | 05:12 PM
SilverBullet08's Avatar
SilverBullet08
i mounted mine right at the pocket under the hood. right by where the headlight adjustment is. no problems with radio interference
Animal Mother
Driving with my lows and fogs on is bright enough for me. I dont think ive used my highs more than 5 times in the last 8 months. As for the drop I couldnt tell you the exact number, it was on the truck when I bought it but thanks!
Old May 12, 2010 | 05:16 PM
Trupiano's Avatar
Trupiano
Yeah Ill prolly just stick with the lows then, and try that rubber trick I was talkin about. Guess I better get started.
Old May 12, 2010 | 05:29 PM
4matty3's Avatar
4matty3
that mustang is awesome
Old May 12, 2010 | 05:36 PM
nateroach's Avatar
nateroach
The distortion you (or anyone else for that matter) are getting from the HID's is ground loop feedback. If you isolate the ballasts (like with your rubber spacer idea) you should be fine. The high voltage of those ballasts (which is required for HID's) is inducing current in the frame, which is also your ground and causing the distortion with your radio.
(I guess it does pay to be a EE sometimes)
nateroach
Old May 12, 2010 | 06:12 PM
JoeHemi's Avatar
JoeHemi
Yeah I heard about the frame thing too so I used some heavy duty adhesive pads to secure the ballast and it hasnt affected the radio one bit.
Trucks lookin good trup
