Hemi vs Cummins
Old Oct 19, 2010 | 01:25 AM
rr-merlin's Avatar
rr-merlin
Default Hemi vs Cummins
I've got a 2002 1500 Quad cab 4x4 with the 5.9L engine. I just got a toy hauler that loads out at about 7200 lbs. Im getting about 3-7 mi per gallon and my tranny goes into over themp on hills. I want to move up to a 2003-2008 2500 4x4, but am really torn with the engine option. I m sure the Cummins is way more than I need, anybody pulling that load with the Hemi that can give me mileage #s? Actually any input on the subject would be great.
Old Oct 19, 2010 | 01:58 AM
AZZO540's Avatar
AZZO540
you just open an intersting can. i say buy both.
nah i have seen ppl pull 10k on hemi but tech should be more for cummins and i own a hemi and will tow with it.
Old Oct 19, 2010 | 08:05 AM
bartvandenberg's Avatar
bartvandenberg
I would go cummins hands down.
They generally get much better mileage, WAYYY more torque, and the simplest things crank up your HP and torque very easily. Just add a programmer, and you've got +100hp easy.
Double that with the 6 speed manual, and you've got MY dream truck!
Towing with the auto tranny's in the older model's (02-04) is something I personally would'nt recommend. the tranny's were not built to tow. the later 5 speed auto was a much better tranny.
Some on here will argue that all they like because they've gotten lucky and their tranny hasnt died yet, but I know a very good handful of guys (if not 2) who own those years, who tow and plow with there trucks, and have the tranny rebuilt like every year.
Did i already say... hands down get a cummins with manual tranny.
Old Oct 19, 2010 | 09:56 AM
Marx's Avatar
Marx
towing 7000#'s 2-4 times a year get the hemi, more than 4 times a year get the cummins
Old Oct 19, 2010 | 10:35 AM
bamataco's Avatar
bamataco
I have owned both. I can pull that much with my Hemi. But I think the deciding factor should be how often do you tow that load. If you tow it often no doubt about it a Cummins is definately the way to go.
Old Oct 19, 2010 | 11:06 AM
kx250frider617's Avatar
kx250frider617
Id get the cummins period. It even gets better fuel mileage crusing around town. Expect the hemi to get 5-8 mpg towing and 3 up hills. I used to tow a 25ft tow hauler fully loaded around 6k pounds and it did it fine but it sucked the gas. Now tow it with a 7.3 powerstroke and it's not even back there and now get 15mpg towing. There really is no comparison between gas and diesel. Id get the 5.9 cummins though, just so you dont have to deal with DPF and all the emissions stuff. I don't know about dodge but the 7.3 powerstrokes didn't even come with a cat.
Old Oct 19, 2010 | 11:32 AM
dirtydog's Avatar
dirtydog
Moderate User
Diesel = Very expensive
Hemi = Good HP/Tq and relatively low cost.
Since you plan to tow just a few times a year, I say get a Hemi and save yourself thousands. You want 3:92 gears or higher.
I've pulled 7,000lbs a number of times and was regularly getting 11-12mpg.
If you decided to re-gear to 4:56's you would get much better mileage while towing heavier loads.
I have 3:92's w/33" rubber. 7,000lbs I could certainly feel it, but in no way was it too much for the Hemi.
Everyone is gonna say diesel, diesel, diesel, but there are many downsides that most don't even consider. Tough trying to find a place that will even work on them.
Old Oct 19, 2010 | 11:43 AM
HammerZ71's Avatar
HammerZ71
I pull about 7700 lbs. in tractor, rough cut and dual axle trailer about 3 or 4 times a year. Only have to pull it about 30 miles each way. I'll average about 8 or 9 mpg with my truck. Pulls it fine on the flat terrain of south Georgia.
If I did it more often, say once or twice a month or had to go a greater distance, I'd have purchased a CTD.
I'm with 'dog on this one, if it's an occasional thing, the Hemi will do fine. Really about the same as your 5.9. Even though the Hemi has 100 more HP, the torque is relatively close between the two engines, so don't expect the Hemi to be a better tow/haul truck. But if you are satisfied with your 5.9, you'll be satisfied with a Hemi.
If you pull it often, very far or put a LOT of miles on your truck in general, then you'd be a perfect candidate for a CTD...
Old Oct 19, 2010 | 11:56 AM
Matt99's Avatar
Matt99
Im with Dog and Hammer also, a CTD has more drawbacks other than initial cost. Maintenance on them is ridiculous, both price and time. They get better mileage but diesel is harder to find and more expensive. Normal run of the mill mechanics cant work on em.
They do offer better towing, better life, and easier HP....but do you tow enough to reap the benefits of the CTD? I say get a Hemi and regear it, and you would still be WAY under what a CTD would cost.
Old Oct 19, 2010 | 01:06 PM
kx250frider617
After actually having a diesel, there's not that much different in price for maintenance compared to gas. Yea the oil changes are 3 gallons but the oil you use is just the regular kind, nothing synthetic. The price of fuel is easily made up in the MPG. You can do all the math you want that suggests otherwise but in the real world diesel is cheaper to operate. Then theres the price of the truck itself but in your case you are buying used and a couple years older which is going to be less than a new hemi if you were to buy one. Im just saying from experience, I would go diesel way before gas even if its not a dodge. Not to mention putting a programmer on it and smoking any hemi out there (majority of them) then driving home getting 20mpg.
