PML trans pan
Old Dec 17, 2010 | 08:10 AM
ccgRAMrod's Avatar
ccgRAMrod
Default PML trans pan
Has anyone run the PML deep trans pan the one that holds about 2 quarts more then stock? I have a '03 2500 4wd and heard you need to drop the exaust pipe lower. Is this easy to do, and how?
thanks
Old Dec 17, 2010 | 09:21 AM
nateroach's Avatar
nateroach
I believe you would have to do that for the PML pan, but mag-hytec makes a notched pan so you don't have to modify anything. I am assuming this is for the 545RFE correct?
http://www.mag-hytec.com/store/index...products_id=88
nateroach
Old Dec 17, 2010 | 09:42 AM
ccgRAMrod's Avatar
ccgRAMrod
Yes it is.
Old Dec 17, 2010 | 01:00 PM
NV290's Avatar
NV290
X2 on the Mag Hytec. It's a work of art.
Old Dec 17, 2010 | 01:34 PM
dirtydog's Avatar
dirtydog
Moderate User
Deeper pans are good for towing etc, but honestly, for that kinda money, I would opt for installing a better trans cooler rather than spending the money on a deeeper pan. Keeping the fluid cool is most important. A deeper pan will just hold more fluid and even though there is more fluid it can still heat up and cause the same issue's a shallower pan will. Stock OEM pan is 7qts anyways which is pretty good.
Now, doing both is optimal, but unless you are maxed out your towing load, it is unnecessary if you keep up on your maintenance!
Old Dec 17, 2010 | 03:24 PM
ccgRAMrod's Avatar
ccgRAMrod
Does the Mag Hytec have a trans temp port?
Old Dec 20, 2010 | 07:49 AM
ccgRAMrod's Avatar
ccgRAMrod
anyone know?
Old Dec 20, 2010 | 08:42 AM
nateroach's Avatar
nateroach
yes, the Mag Hytech has a port for temp probe. it is a 1/8" and has a pipe plug installed when it ships. just take out the plug and thread in your sending unit and your good to go.
instructions:
http://www.mag-hytec.com/Dodge%20Tra...RFE_545RFE.pdf
nateroach
