Best way to level a truck??
Old Jan 30, 2011 | 02:41 PM
Jake283's Avatar
Jake283
Default Best way to level a truck??
Hey i have a 2004 dodge ram 1500 2wd and i was wonderin whats the best way to level out my truck? at first i was gonna do coil spacers but im hearing that it makes the ride a little stiffer, but is there any other way i could do it that wouldnt mess with the ride?? and if anybody knows of a good 3 inch body lift the comes with the bumper brackets and everything i need included with it could you give me a link to it.
thanks, Jake
Old Jan 30, 2011 | 02:45 PM
Matt99's Avatar
Matt99
the best way is spindles. look at airbagit.com
PA makes a body lift for your truck. You could find it cheaper.
http://cgi.ebay.com/ebaymotors/03-05...Q5fAccessories
Old Jan 30, 2011 | 03:29 PM
Jake283's Avatar
Jake283
Thanks bro, and do the coil spacers really make the ride that much worse or is it even noticable?
Old Jan 30, 2011 | 03:32 PM
Matt99's Avatar
Matt99
its noticeable. I would have gone spindles if I would have thought about them at the time. Its the way to go.
The spacers degrade the ride as they get taller, but you will get a more level stance and a better ride overall from spindles. If you factor in shocks, they dont end up being THAT much more.
Old Jan 30, 2011 | 03:38 PM
Jake283's Avatar
Jake283
well the spacers i was looking at were the ones you gave the website to
http://store.fatbobsgarage.com/_dodg...011-p1740.aspx
and in what ways do the spacers feel stiffer? like when hitting a bump?
Old Jan 30, 2011 | 03:47 PM
Matt99's Avatar
Matt99
ohh I didnt recognize your name, I remember now.
The spacers feel stiffer in all driving. They compress the coils, allowing for less compression. Bumps are when you really feel it, but even everyday driving has a different feel to it.
With yours being an 04 and you looking at 2in spacers, it not that big of a deal. You wouldnt be dissapointed. Im just telling you that the best way to level is spindles, and I would have gone that way myself if I had it to do over again.
If your budget is super tight (like mine was) then just go ahead and do spacers. You could always throw spindles on later and have 5in of lift up front!
Old Jan 30, 2011 | 04:20 PM
Jake283's Avatar
Jake283
Okay thanks man. ill prob go with just the spacers since i am gonna have a tight budget. then get spindles when i have more money, im gonna do it all this summer, im gonna do the 2 inch spacers then the 3 inch pa body lift, then put some 35's on some 18's, it will be a while from now but ill make sure to put pictures up on here when im done with it. Thanks again.
Old Jan 30, 2011 | 04:36 PM
HammerZ71's Avatar
HammerZ71
I'm curious, how is a body lift going to level your vehicle? Or are you thinking level kit AND body lift?
Personally, for only 2" of lift I would get the spacers. Spindles are better for more lift, but at only 2" I don't think the ride will degrade much at all. If money is no object, go with the spindles, but don't be afraid of spacers, either.
I am by no means an 4x2 expert, but I've lifted a good many coil over 4x4s, including my own Grand Cherokee (2" coil spacers at all 4 corners, aka BB or Budget Boost). I have far better shocks than were on it stock, so I think my ride quality is better even after the coil spacers than it was stock...
Old Jan 30, 2011 | 04:50 PM
Jake283's Avatar
Jake283
Yea im gonna put the level on and the 3 inch lift, sorry to confuse you, and thanks, im pretty tight on money so im gonnna do the spacers, thanks
Old Jan 31, 2011 | 08:57 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Just dont forget the alignment afterwards.
