Wheel offset??
Old Feb 1, 2011 | 05:39 PM
Jake283's Avatar
Jake283
Default Wheel offset??
Hey im looking at some wheels and it has a -12 offset. i want my wheels to stick out of the side of my truck a little. cause i like the look. and i was wondering if anybody here had some wheels with -12 offset and i could see how much it sticks out?
Heres a pic of the rims im getting.
Old Feb 1, 2011 | 06:21 PM
MikeHTally's Avatar
MikeHTally
I have 17x9s with -12mm offset. I'm looking for flares for it.
This is the closest pic I have of a profile view:
Old Feb 1, 2011 | 07:25 PM
Jake283's Avatar
Jake283
yea i can kinda see a difference. do you have any pics of the side of your truck? and what size tires do you have on there??
Old Feb 1, 2011 | 08:09 PM
HammerZ71's Avatar
HammerZ71
What's the backspacing? Need to know both backspacing and offset to figure out how far they will stick out...
Old Feb 1, 2011 | 08:12 PM
MikeHTally's Avatar
MikeHTally
285/70. 2 1/2" level kit.
Old Feb 1, 2011 | 09:05 PM
Jake283's Avatar
Jake283
Offset: -12mm Backspacing: 4.56
Old Feb 1, 2011 | 10:33 PM
HammerZ71's Avatar
HammerZ71
Almost identical specs as my wheels. This should give you a general idea of stance with 12.5" wide tires:
Old Feb 1, 2011 | 11:36 PM
Jake283's Avatar
Jake283
okay awesome, looks good.
Old Feb 10, 2011 | 12:11 AM
BigTXRam's Avatar
BigTXRam
what wheels (brand/modle) are your rims Hammer? Also, since I'm probably going to be in the market myself for some new rims what if I want them to stick out a little farther? is the lower the number backspacing the farther it sticks out? Also, since im planning on going with a 35x12.50 should I look for a 10 inch width rim or is 9 still ok? I was told a 12.5 on a 9 in width rim would make the tire sit tall and wear out faster in the middle, is that true or was the guy blowing smoke? I dont know squat about this stuff, but Im freaking thankful you guys are out there.
Old Feb 10, 2011 | 06:44 AM
HammerZ71's Avatar
HammerZ71
The guy don't know his a$$ from a hole in the ground. Ideal specs are the tire should be 3" wider than the wheel, with 1" + or - being in spec. My wheels are Mickey Thompson Classic IIs, nothing fancy, relatively inexpensive aluminum wheel with a very good strength to weight ratio. Size is 17x9, either a 9" or 10" wide wheel would be fine.
My tires at 30k miles, I think they are wearing just fine:
