Cam help!!!
Old Feb 2, 2011 | 03:02 PM
  #51
SLT8's Avatar
SLT8
Yep like i said its a bad example BUT with the 114-3lsa its very easy to tune and some have been able to idle using SC3815 91 tune and Hypertech. Running good is another story + the additional mods you are going to need to compliment the cam + 7k shifting. Yep mine is coming out lol.
Cam in a 03 using Hypertech.
http://www.youtube.com/watch?v=1zwKQfdWD2g
Old Feb 2, 2011 | 03:05 PM
  #52
truckin151's Avatar
truckin151
Superchips will not do a custom tune. You can ask around but any cam that needs to have the idle adjusted to run is basically out of the picture. If its just a fuel trim and timing issue I am fairly sure thathe dsp can do that for you but that's about it.
Old Feb 2, 2011 | 03:25 PM
  #53
weedahoe's Avatar
weedahoe
Hall of Fame Member
Its all been said a few times but I dont think it is sinking in. The biggest thing holding you back is your 2003 PCM in that truck.
You cannot do ANY custom tuning worth tuning.
So forget any cam less than 114 LSA. You are just going to kick yourself in the rear and want to shoot yourself.
It cant get any more simple or clear that than.
The ONLY way to successfully and fully custom tuned is to swap out your 2003 PCM/TCM with an 04+ setup.
LOTS of people have asked about it. NO ONE has done it because NO ONE is sure it will work.
I am about to do a PCM/harness swap and as far as i know, I will be the first. If it works I will be better off. If it doesnt work then I will have blown a lot of money for the gear.
So stick with a cam at 114+ LSA.
That means Superchips if your best bet as a tuner.
Old Feb 2, 2011 | 03:35 PM
  #54
SilverBullet08's Avatar
SilverBullet08
1 person has done the pcm swap on nadodge...
Old Feb 2, 2011 | 03:47 PM
  #55
weedahoe's Avatar
weedahoe
Hall of Fame Member
Gimmie a link please
Old Feb 2, 2011 | 03:52 PM
  #56
SLT8's Avatar
SLT8
I read that thread a few weeks ago. I think it was flossin or someone he knows.
Old Feb 2, 2011 | 03:54 PM
  #57
SLT8's Avatar
SLT8
Found it. Its his buddy... 03 to 05 swap
http://nadodge.com/showthread.php?t=5193&highlight=swap
Old Feb 2, 2011 | 04:01 PM
  #58
irunlightnings's Avatar
irunlightnings
Okay thankyou soo what would b the best brand and model that you guys would trust?
Old Feb 2, 2011 | 04:08 PM
  #59
SilverBullet08
for what
Old Feb 2, 2011 | 05:55 PM
  #60
irunlightnings
Best brand of cam and model with loud lope tht my truck can handle...I guess its a 114
