Cam help!!!
Old Feb 2, 2011 | 07:52 PM
  #61
irunlightnings's Avatar
irunlightnings
Originally Posted by kay9
Yep like i said its a bad example BUT with the 114-3lsa its very easy to tune and some have been able to idle using SC3815 91 tune and Hypertech. Running good is another story + the additional mods you are going to need to compliment the cam + 7k shifting. Yep mine is coming out lol.
Cam in a 03 using Hypertech.
http://www.youtube.com/watch?v=1zwKQfdWD2g
would this b dueable??
Old Feb 2, 2011 | 09:15 PM
  #62
SLT8's Avatar
SLT8
I would stay away far from it. That is just an idle video. Who knows how it runs in closed and open loop. I don't know what mods you have but i have quite a few with custom tuning and i am about to take the cam out. Its a real high rpm cam that is good in cars and strokers. You will need 4.56/4.88 gears AND 3400 stall and pretty much every bolt on. Then have rev limiter removed so you can shift at 7k. Not worth it on a stock block.
Go with a Comp 260, Crazy Jay.
Old Feb 2, 2011 | 09:24 PM
  #63
SLT8's Avatar
SLT8
Here is a Comparison Chart for the Comp Cam lineup. As you can see the Comp 260 would be the cam of choice for you.
Old Feb 2, 2011 | 10:49 PM
  #64
irunlightnings
Soo u say I should get a crazy jay comp 260? I have exaust intake superchip throttle body shift kit idk what gears cuz this guy I bought it from only said it has exaust but I saw throttle body nd shift kit was on it so god only knows wat else it has...it has a lil lope as of now idk if its due to no muffler on my exaust and the exaust is shortened? But u say a comp 260
Old Feb 2, 2011 | 10:59 PM
  #65
truckin151's Avatar
truckin151
Yeah, the 273 is such a high rpm cam that it really isnt meant for a truck. 7k in a truck to get it into the meat of the powerband just is not worth it. The 268 is a much more friendly street cam with the right mods and if you can tune it, you will still need 410-456's and at least a 2800-3200 stall converter but it will not run with out a tune and without the idle upped or it will stall out. The 260 will run on a canned tune and should have no issues with the superchips tuner, no custom tune needed, it builds it power in the right spots so it should work well for your application.
Again, ones that will work with your truck,
Crazy Jay - Inertia Motorsports
Crazy Spartan - Inertia Motorsports
FRI Sidewinder - Franks Racing / Comp Cams
Comp 260 - Comp Cams
OR
You can buy a 6.1 cam which you can get for cheap and send it down to inertia for a regrind to any spec that you want, it will give you more options for the cam and still be easily tuneable for your application. If I were you I think I would at least give them a call and see what you can get done to get you the most bang for your buck.
Old Feb 2, 2011 | 11:07 PM
  #66
truckin151's Avatar
truckin151
So you dont know what gears it has? Thought you said it had 4.10's? Lope is more than likely from the exhaust. Mine had a slight lope with the exhaust only. Also thought you said you had a Borla exhaust, now you are saying you dont have a muffler at all?
Old Feb 2, 2011 | 11:19 PM
  #67
irunlightnings
No I have only the cat in and the borla tips is all I hav I moved it out b4 my tire like a lightning and I made my pipes to 3.5 inch.but about my gears idk how to figure out what I have I have posi...I think 4:10 but my buddy thinks 3:73
Old Feb 2, 2011 | 11:20 PM
  #68
irunlightnings
Outta my options u listed which would have a bigger lope and more horsepower?
Old Feb 2, 2011 | 11:27 PM
  #69
truckin151's Avatar
truckin151
All of them will have about the same lope or close to one another. HP/TQ numbers you are going to have to do some research. Start emailing places or calling them and ask. Comp gets back to you real quick, inertia will help you out with pretty much anything you want too.
Old Feb 2, 2011 | 11:32 PM
  #70
irunlightnings
okay thanks if I have 3:73 I can't do a comp 268 but 410s I can pull it off?
