Cam help!!!
Old Feb 2, 2011 | 11:36 PM
  #71
truckin151's Avatar
truckin151
no. the 268 needs a tune and idle raised. you cannot do that in an 03'
Old Feb 2, 2011 | 11:38 PM
  #72
irunlightnings's Avatar
irunlightnings
Thks for the help...ill take a video of her now nd try to put her on tomorrow then ill tak one after the install and put it on...thks for the help every1
Old Feb 2, 2011 | 11:41 PM
  #73
irunlightnings
Ahhhhh damn this 03 haha but okay 260 it is then thks man
Old Feb 3, 2011 | 08:05 AM
  #74
weedahoe's Avatar
weedahoe
Hall of Fame Member
If you got the coin I will sell you my 04 PCM and harness. Then you can get custom tuned and run whatever cam you want.
But until then, IMO, your ONLY options are those Truckin151 said back up in post 65
Old Feb 3, 2011 | 08:28 AM
  #75
irunlightnings
Yea but I dnt really wanna drop like 1500 in a cam haha nd pcm nd tuning nd labor soo...out of my options I believe they would all sound the same? And which option would u go with? Like brand u trust most and loudest lope?
Old Feb 3, 2011 | 09:04 AM
  #76
truckin151's Avatar
truckin151
Either go with the 260 or the FRI Sidewinder and you wont be disappointed. Lope on all of them will be about the same, they should all be around a 114 lsa.
Another thing to note is that all of the guys that posted up soundclips here have Long Tube Headers and cutouts which will magnify that lopey idle and make it come through even better than it would through the stock manifolds and piping. So keep that in mind if you are just wanting the sound. If you are only doing this for the sound, which from every post so far thats what it sounds like, you really need to think this one through.
Old Feb 3, 2011 | 09:09 AM
  #77
irunlightnings
About how much horsepower will the 260 gimme??? And is it a mid range?
Old Feb 3, 2011 | 10:01 AM
  #78
truckin151's Avatar
truckin151
The 260 is a lowend cam or a tq cam but it will do what you need it to do. It will buikd power early in the rpm range and go to about the 5500rpm range so right where you need it. Power wise, probably an additional 20hp/tq across the board depending on supporting mods
Old Feb 3, 2011 | 10:57 AM
  #79
SilverBullet08's Avatar
SilverBullet08
if you have a 1500 then your gears are either 3.55 or 3.92s. unless someone before put in aftermarket ones. then it could be 410s, 4.56s or 4.88s (only 2wd)
the 260 is alright but the sidewinder has more power and tq then it and is overall better imo
Old Feb 3, 2011 | 12:03 PM
  #80
weedahoe's Avatar
weedahoe
Hall of Fame Member
New camshaft and everything to go with it is going to be close to a grand with you doing the install your self anyway.
