Bigger oil filter
Old Feb 2, 2011 | 07:25 PM
Brew_City_Mopar's Avatar
Brew_City_Mopar
Default Bigger oil filter
In case anyone was wondering. The wix 51773/napa 1773 and AmsoilEao-26-ea all fit the 02-05 Hemi's.
They add about 1.5 quarts of oil capacity.
Old Feb 2, 2011 | 09:11 PM
stenerson's Avatar
stenerson
I use oversized filters. 1.5 more quarts? I doubt it.
Old Feb 2, 2011 | 09:39 PM
Brew_City_Mopar
It's a big filter. It takes about 8.5 quarts to fill my truck with that filter. Here are the specs:
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 6.982
Outer Diameter Top: 3.663
Outer Diameter Bottom: Closed
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Burst Pressure-PSI: 290
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 32"
Old Feb 2, 2011 | 09:52 PM
03MopaRamman's Avatar
03MopaRamman
Interesting!
Old Feb 2, 2011 | 10:23 PM
stenerson's Avatar
stenerson
Service: Lube
Type: Full Flow
Media: Paper
Height: 6.982
Thread Size: 3/4-16
Hmmm? That's larger than the oversized versions I've used. I wonder if that large Micron Rating is a problem?
Old Feb 2, 2011 | 10:36 PM
Brew_City_Mopar
Thats the specs for the 1773, the amsoil filter has a micron rating of 15.
Old Feb 2, 2011 | 10:38 PM
stenerson's Avatar
stenerson
Thanks for the info. I like to find a cross reference for those filters for M1, KandN etc.
Old Feb 3, 2011 | 06:55 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Interesting indeed! That much be a big filter.
