2wd lift spindles...what next..?
Old Feb 6, 2011 | 12:33 AM
bikerglasses's Avatar
bikerglasses
Default 2wd lift spindles...what next..?
I did the airbagit 3" lift spindles. I thought I'd be happy with the lift, but I want more... of course..
Thinking of doing..
3" lift springs
3" rear blocks OR add-a-leafs (pros/cons?)
bilstein shocks front and rear (extended or stock length?)
Is there a site that sells everything together reasonably, or should I piece them from from sites... if so, which ones? Do I need to do extended brake lines? And do I need extended shocks?
Thanks,
Ian
Old Feb 6, 2011 | 08:51 AM
rideon20z's Avatar
rideon20z
3'' body lift
Old Feb 6, 2011 | 10:23 AM
weedahoe's Avatar
weedahoe
Hall of Fame Member
Remember you have an 08 so 3" spindles + 3" lift springs wont work. You will hit the UCAs
Old Feb 6, 2011 | 08:52 PM
bikerglasses
Had no idea I couldn't do springs...that sucks ...didn't wanna do body lift!
Old Feb 7, 2011 | 12:06 PM
bikerglasses
So body lift is my only option?
Old Feb 7, 2011 | 03:04 PM
weedahoe's Avatar
weedahoe
Hall of Fame Member
http://www.cstsuspension.com/product...6/productID/37
Old Feb 7, 2011 | 03:23 PM
bikerglasses
They show new springs....
Old Feb 7, 2011 | 05:16 PM
bikerglasses
Oops just read it says they don't make lift springs for v8
Old Feb 8, 2011 | 12:13 AM
Matt99's Avatar
Matt99
You dont want more than 2in of lift between the control arms. Trust me lol
Tell us about the spindle lift. Pics, install, etc. Im wanting to do this pretty soon
And I dont understand what everyone has against the body lifts. I think they look fine.
Old Feb 8, 2011 | 12:07 PM
bikerglasses
Spindles are good. I didn't do the install and a friend of a friend who's a mechanic do it. He had access to the alignment machine too so he was able to do that for me also. He said it was pretty straight forward. I told him about swapping the brake lines and at first he's like hmm.. dunno about that, and then he said while he started taking the passenger side off he could see it'll work because the bend is different.
I'm extremely happy with the way the spindle leveled the truck, the truck looks completely level now. Just would be happy with a little more height.
I've posted before there's 2 things to look out for with the airbagit spindles:
1--they're raw, so they should be painted, or powercoated.
2--they don't have the hole drilled on the drivers side for the ABS sensor.
Now after knowing this I wish I would've painted them, preferably powdercoated, but here in Arizona it won't be as bad as being back east. And I wish I would've pre-drilled the hole.
