OTIS to EVIC for 07 RAM
#21
Searching on eBay is a bit of an art. Here's a simple search if you want to look by part number. It will check both the title and description for part number 56046038*. You can modify the part number as you like:
http://www.ebay.com/dsc/i.html?_nkw=...LH_TitleDesc=1
Many times, though, the seller will not include the part number and you must look at the photos. This search is heavily filtered, but it will still give you lots of junk. The key is: after you run the search, sort the list by 'newly listed' and then save the search and schedule it to run every day and send you an e-mail. This way, items posted in the last 24 hours will be at the top of the list:
http://www.ebay.com/sch/i.html?_nkw=....c0.m270.l1313
You will need to know whether you need PCI or CAN bus, and look at the pictures for part numbers, etc. Becoming familiar with how the buttons are laid out will help, too.
#23
#24
Edit: The wires are not different in the connector. I hooked the 56046038AC up to an '08 Ram, and it turned on, worked, let me run through the settings, showed everything exactly as it should. So I know for sure that it's not an issue with the module. For whatever reason, this particular one is not communicating with the 06 truck.
#27
I know this thread is old, but I too tried the swap in an 06 ram, with no luck. After digging a little deeper, I found interchanges for all modules. and it appears the 06 will not interchange with the evic unit nor is there one that will work. My guess is, since 06 was the first year of canbus on the rams, they did not have a way of communication with the evic unit to the bcm. I'm pretty bummed out about it, but at least i can stop "trying" to make it work. Here is what I found for interchanges via moparpartsoverstock.com "I have not personally verified any working part #s, so please use this as a reference only.
Evic with Homelink : 56046107AC ; 56046038AC; 56046107AA; 56046107AB
07-08 Ram 1500
07-09 Ram 2500-3500
07-09 Aspen
07-09 Durango
Evic without Homelink : 56046109AC ; 56046037AA; 56046037AB; 56046109AA; 56046109AB
07-08 Ram 1500
07-09 Ram 2500-3500
08-10 Ram 4500-5500
Otis with Homelink : 56044864AD ; 56044864AA; 56044864AB; 56044864AC; 56049089AA; 56049089AB; 56049089AC; 56049089AE; 56049089AF; 56049089AG; 56049089AH
05-11 Dakota
04-06 Durango
06-09 Ram 1500-2500-3500
Otis without Homelink : 56049824AD ; 56049824AA; 56049824AB; 56049824AC
06-09 Ram 1500-2500
06-10 Ram 3500
*A couple of the years must be carryover years or "classic" models, so please note fitment exceptions, and I hope this was helpful
07-08 Ram 1500
07-09 Ram 2500-3500
07-09 Aspen
07-09 Durango
07-08 Ram 1500
07-09 Ram 2500-3500
08-10 Ram 4500-5500
05-11 Dakota
04-06 Durango
06-09 Ram 1500-2500
06-10 Ram 3500
#29
Thanks for digging this info up.
However, I know for a fact that the 2006 Dodge Ram 2500 has an evic. My brother in law owns one, and it is indeed an EVIC, not an OTIS like what is in my truck. I have not had the opportunity to pull it down and check a part number on it yet, but the next time I get the opportunity, I am going to. Once I get that part number I'll post it here. I'm also going to try to put it in my truck when I take it down, and see what happens.
When I replaced the OTIS with the EVIC I bought for my truck in a buddy's truck, it worked instantly. No reprogramming, disconnecting the battery, resetting anything. So we'll see how it goes when I get the chance.
#30
I've searched around on ebay quite a bit and all the 06 Laramie rams for sale that show the console seem to have the Otis with homelink. Maybe your brother-in-law got one of the last 06 models and it has the capability? Does he have "tap to pass" tap the blinker and it will flash 3 times which is enough for a lane change. They started it in 07. New vehicle model years are usually started in June or July of the previous year, so the 07 trucks probably started around June of 06. With that being said, mopar overstock has production dates on these consoles which date back to 6/19/06. I'd love to be able to have the evic if it's possible, so any last bit of hope is appreciated. Let me know what you find out JoshuaAckley!
